SM-J330fn server unlock code [Done] UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.9 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This opreratin takes 5 credits.Continue? Yes Searching Samsung modem... detected COM78 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQF9 CSC version: J330FNBTU1AQF2 CP version: J330FNXXU1AQF7 Product code: BTU Phone SN: R58J93K3FNV Unique number: CQE004167E00484 Searching Samsung diag port... detected COM77 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 57374249 NET lock: 06385830 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
another one with 4cr only :) UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-J330FN Software version: 29.9 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This opreratin takes 4 credits.Continue? Yes Searching Samsung modem... detected COM106 Reading phone info... OK Model: SM-J330FN AP version: J330FNXXU1AQF9 CSC version: J330FNBTU1AQF2 CP version: J330FNXXU1AQF7 Product code: BTU Phone SN: R58J939NJHD Unique number: CQE000428E44384 Searching Samsung diag port... detected COM107 Reading phone info... OK CP version: J330FNXXU1AQF7 CP build: Jun 15 2017 15:50:55 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 83825358 NET lock: 63924090 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.9 |
J3 Pro SM-J330FN Read Codes error (1) Phone Knox is voided (0x01(void)) But you say Reading codes using sever ('Upload' algo): Knox warranty does not matter Operation: Read Codes via Server Selected model: SM-J330FN Software version: 30.2.2 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 Product code: SM-J330FZSNXEF Phone version: J330FNXXU1AQF7 PDA version: J330FNXXU1AQF9 CSC version: J330FNXEF1AQF4 CSC country code: France CSC sales code: XEF HW version: MP 0.500 Phone SN: R58J96YS48V Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-06-01 RF cal date: 20170930 IMEI: 353644090017219 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM11 detected Calculating... error (1) Done with Samsung Tool PRO v.30.2.2 Please Fix Soon |
any solution ??????????????????????? Operation: Read Codes via Server Selected model: SM-J330FN Software version: 30.8 Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 Product code: SM-J330FZKNBTU Phone version: J330FNXXU2AQK8 PDA version: J330FNXXU2AQK8 CSC version: J330FNOXA2AQK8 CSC country code: UK & IRE CSC sales code: BTU HW version: MP 0.500 Phone SN: R58JB6AF31H Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-12-01 RF cal date: 20171129 IMEI: 353644096781982 Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM9 detected Calculating... error (1) Done with Samsung Tool PRO v.30.8 |
maybe this is new security !! so z3x new security not added !!!! |
Same issue with me, any solution ?! |
same here: Operation: Unlock Selected model: SM-J330FN Software version: 33.5 Searching Samsung modem... detected COM1324 Reading phone info... Model: SM-J330FN AP version: J330FNXXU2AQK8 CSC version: J330FNVFG2AQL1 CP version: J330FNXXU2AQJ1 Product code: CNX Phone SN: R58K4xxxxx IMEI: 35573009xxxxxx Unique number: CQE002C89CC0915 Reading IMEI... OK IMEI: 35573009xxxxxx Reading SN... error (1) Done with Samsung Tool PRO v.33.5 |
UNLOCK DONE J330F DS Operation: Read Codes via Server Selected model: SM-J330FN Software version: 33.5 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM99 Reading phone info... Model: SM-J330FN AP version: J330FNXXU2AQK8 CSC version: J330FNXEF2AQK2 CP version: J330FNXXU2AQK8 Product code: XEF Phone SN: R58K32E3XGB IMEI: 355730094637660 Unique number: CQE009EE9D052B4 Searching Samsung diag port... detected COM98 Reading phone info... OK CP version: J330FNXXU2AQK8 CP build: Nov 22 2017 15:56:18 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 15075207 NET lock: 17480971 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.5 |
In last 33.5 used UPLOAD method and crashes Modem, abd then cant read phone, so still error Then used NEW method wich still gives error, and that on bit 2 sec.... Had to flash phone few times and then succeed with NEW. |
Sm-j330fn 7.0 unlock possible with z3x??? Sm-j330fn 7.0 unlock possible with z3x??? If yes how to do it ??? |
j330f unlock hi i want to know how many credit take unlock operation thanks |
it only take 5 5 credits bro....thats all u need bro |
