02-25-2017, 07:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | G532f flash faild FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G532F Software version: 27.7 File analysis... Ok Total file size: 0xBEEC6D40 (3054 Mb) Searching USB Flash interface... COM34 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending preloader.img... Ok Sending lk.bin... Ok Sending param.bin... Ok Sending trustzone.bin... Ok Sending efuse.img... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... error It looks like you have an unsucessful operation, try this link for solution - inurl:f453 site:http://forum.gsmhosting.com/ "Selected model: SM-G532F" "Sending system.img error" - Ïîøóê Google Done with Samsung Tool PRO v.27.7 how can i flash this phone? |
The Following 4 Users Say Thank You to hippolyte85 For This Useful Post: |
02-25-2017, 08:14 | #2 (permalink) |
Member: 361348 Status: Offline Thanks Meter: 635 | sorry its ok battery was just low FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G532F Software version: 27.7 File analysis... Ok Total file size: 0xBEEC6D40 (3054 Mb) Searching USB Flash interface... COM34 detected Setup connection... Ok Set PIT file... Ok Reading PIT from phone... Ok Sending preloader.img... Ok Sending lk.bin... Ok Sending param.bin... Ok Sending trustzone.bin... Ok Sending efuse.img... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending secro.img... Ok Sending userdata.img... Ok Sending md1dsp.img... Ok Sending md1rom.img... Ok Flashing done (time - 00:04:09) Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to hippolyte85 For This Useful Post: |
