01-15-2018, 22:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | Sm-g925a read code last build for dummies qj2 UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Read Codes Selected model: SM-G925A Selected port: COM55 SAMSUNG Mobile USB Serial Port Software version: 30.5 Searching Samsung modem... detected COM54 Reading phone info... OK Model: SM-G925A AP version: G925AUCS6EQJ2 CSC version: G925AATT6EQJ2 CP version: G925AUCU6AQC1 Product code: ATT Phone SN: R38H50TP8RR Unique number: 1115FBB5645E0603 Reading IMEI... OK IMEI: 3579ddddddddddddddude (SIGN: OK) Please wait, generating hash codes file, this can take few minutes... OK Reading data from phone... OK HWID: A8 FF 7E 6C 77 04 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:00) Freeze code: 52814852 NET lock: 72720917 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.5 |
