04-23-2019, 19:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2010
Member: 1212133 Status: Offline Thanks Meter: 58 | What kind of UART cable I want to remove FRP in Samsung G935F. Is it possible to use UART micro cable that has USB connector instead of LAN connector? Is there any difference if there is LAN or USB connector? Thanks |
04-23-2019, 19:29 | #2 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hello, the uart cable is the rj45 c3300-c3303-530k resistor model look at the link and the cost and how the uart cable is made. https://gsmserver.com/octoplus-micro...530k-resistor/ To use it, the rj45 part for box and the usb 2 part must be connected to the phone jack, watch the video and see how it works using frp reset using the uart cable method https://www.youtube.com/watch?v=C6vdA2BIRIA Now that to reset the FRP only with the UFS memory method via UART cable only works on Android 6.0.1 and Android 7, to reset FRP on Android 8 you need to install the combination then reset the FRP with the UFS cable UART memory method , otherwise it will not reset without a combination if the phone has Android 8 installed | |
