05-04-2019, 04:03 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Online Thanks Meter: 2,769 | Lg ls770 unlock done but no gsm network supported models: 1570 Reading timeout, check cable Error Code: ReadInfo,1,1 Elapsed: 3 secs. --> (v9.60) Mode: Emergency Model: LS770 Read info... Laf Protocol: 01000003 Model name: LGLS770 Software verion: LS770ZV8 Android verion: 6.0 Target operator: SPR Target country: US Chipset: msm8916 IMEI: 356434071506712 Elapsed: 4 secs. --> (v9.60) Phone mode is DOWNLOAD Start new sprint unlock... Laf Protocol: 01000003 Model name: LGLS770 Software verion: LS770ZV8 Android verion: 6.0 Target operator: SPR Target country: US Chipset: msm8916 IMEI: 356434071506712 Init EXT4 /system ... done Detecting sprint type ... using old write method... done Unlocking... Init EXT4 /carrier ... done done Unlock done! Elapsed: 83 secs. --> (v9.60) |
05-04-2019, 04:05 | #2 (permalink) |
Member: 1677653 Status: Online Thanks Meter: 2,769 | Dear team & fellow users, is there any way to convert lg ls770 to gsm network? I have successfully unlocked it before i noticed it's cdma device. Please help. Thanks in advance |
05-04-2019, 23:39 | #3 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
If it's the Sprint version Stylo3 then it will work on GSM, but if it's the Boost version it will not since they actually leave out the GSM chipset at manufacturing. | |
The Following 6 Users Say Thank You to BillA For This Useful Post: |
05-20-2019, 12:19 | #6 (permalink) | |
Just because you see LTE/CDMA is because they use the same firmware base as for Sprint, but it doesn't mean it will have the bands you need. Forget about the APN for now (that's for data only), can you at least make a call? If yes, only waste time on fixing the APN. | |
05-20-2019, 12:40 | #7 (permalink) | |
Member: 1677653 Status: Online Thanks Meter: 2,769 | Quote:
03-29-2020, 22:00 | #8 (permalink) |
Insane Poster Join Date: Aug 2019 Location: Kano
Member: 2925718 Status: Offline Sonork: 100.1683235 Thanks Meter: 26 | Hello there is the solutin how to convert ls770 to gsm try to use qxdm to convert it to gsm network by changing nvitem: 441 to 0xFFF 946 to 0x0028 1877 to 2622339 Download tools click here |
The Following User Says Thank You to Ibrahim_Salisu For This Useful Post: |
03-31-2020, 21:04 | #9 (permalink) |
Member: 2925718 Status: Offline Sonork: 100.1683235 Thanks Meter: 26 | please try Ibrahim_Salisu solution it work for me it is my solution it is working successfull.......................... |
