Old 06-19-2018, 23:18   #46 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
thanks to mkgunner and ky_bAttaUsAi for the hint.
My experience
I had T580XXU2BRB2 XEF android 7.0
After several unsuccessful tests I decided to downgrade (hint above)
1 I flashed COMBINATION_FA60_T580XXU2AQL2
2 I flashed again T580_XXU2APL4_OXA2APL4
3 enter your real wifi details
4 enter again some fake text in the wifi details.
5 select/highlight the entered text
6 you have now google assist (Bingo)
6 type calc in google search bar, you have now the calculator
8 run the calc and enter (+30 012 012 732 + then *#0808# in the DRParser
9 enable DM + MODEM + ADB and reboot
10 use Z3x to remove the frp.
11 enable oem unlock and perform factory reset
I think is is an optimal way.
Operation: Reset FRP
Selected model: SM-T580
Software version: 32.7
You must activate ADB before reset FRP  Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA  Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-T580
Android version: 6.0.1
PDA version: T580XXU2APL4
CSC version: T580OXA2APL4
Phone version:
Product code:
CSC country code: France
CSC sales code: XEF
Phone SN: R52J209ZKTX
IMEI:
HW version:
RF cal date:
Chip name: EXYNOS7870
Modem board:
Security patch: 2016-12-01
Boot Warranty bit: 0
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.32.7
The Following 3 Users Say Thank You to :Aishur: For This Useful Post:
Old 07-12-2018, 12:52   #47 (permalink)
Member: 742687
Sonork: sunilbansal
Thanks Meter: 21
ms-t580 frp remove in umt without downgrade &commination file 1000%done
Device: Samsung Device
Operation: Reset FRP (New Method)
Port: COM105 : SAMSUNG Mobile USB Modem #40
Checking for Device... Found [Normal Mode]
Reading Phone Information... OK
Model: SM-T580
IMEI: NONE);UN(CAJ03A
Software: T580UEU2BQL1/T580XAR2BQL2/T580UEU2BQL1/T580UEU2BQL1
Init Download Mode... OK
Port: COM11 : SAMSUNG Mobile USB Modem
Reading Data from Phone... Done
Chipset: LSI7870 [HiSpeed]
Resetting FRP Lock Data... . Done
Closing Session... Done
The Following User Says Thank You to sunilbansal For This Useful Post:
Old 07-12-2018, 12:57   #48 (permalink)
Member: 742687
Sonork: sunilbansal
Thanks Meter: 21
sm-t580 frp without downgrade commication file1005 okkkkk
Model: SM-T580
Old 08-11-2018, 16:16   #49 (permalink)
Member: 1839092
Thanks Meter: 12
help
does anyone have t580 u3 combination files? thnx
Old 08-23-2018, 14:12   #50 (permalink)
Member: 188484
Thanks Meter: 117
frp t580 last patch.flash with this combination after flash system with z3x .
Old 08-23-2018, 19:17   #51 (permalink)
Member: 92260
Thanks Meter: 843
Try the Rev-2 combi, sometimes it lets you flash it (but usually not).
Rev-3 should be out sometimes soon.
Old 09-17-2018, 07:21   #52 (permalink)
Member: 2706104
Help me with Frp -tablet t580 bit 3 (newest update)
Hi all !
I've been trying to get frp unlocked on this tablet for over a week, tried all the workarounds I could find, but none worked on this new bit 3 rom.
I'd really need a helping hand, some have already tried (I'm willing to pay for unlock frp service) but still haven't found a solution.
Can anyone please help ?
Old 09-17-2018, 07:59   #53 (permalink)
Member: 2604086
Sonork: WHATSAPP-12142824404
Thanks Meter: 39
Anyone else use a Frp server?
The one I use did not work. I think it failed because this is a wifi device with no imei
I also tried to enable ADB by building a sboot and boot.img from combination file only to get a black screen
Anyone else have any ideas for my buddy in FRANCE?
Old 09-18-2018, 13:47   #54 (permalink)
Member: 2706104
would be needing a helping hand on this... any android gurus willing to help ?
Old 10-25-2018, 08:53   #55 (permalink)
Member: 346148
Thanks Meter: 27
t580 frp
hi
need combintion file b3 for tab samsung t580
this one or same u3
COMBINATION FA60 T580XXU3ARG1 CL10816856 QB18828314 REV00 user mid noship.tar.md5.7z
thanks
Old 10-25-2018, 09:02   #56 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
Originally Posted by zahaf View Post
hi
this one or same u3
thanks
****************************/file/aydal...4ARJ1.zip/file
((Open)) file with winrar not direct extract the pass is on the right side this is bit 4 so no backward to bit 3
The Following 2 Users Say Thank You to souma_k For This Useful Post:
Old 10-25-2018, 10:41   #57 (permalink)
Member: 346148
Thanks Meter: 27
can i use it on my phon bit3 or i must upgrade my fone to bit4
before flasing it to enrer adb
Old 10-25-2018, 10:42   #58 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 1,273
After flash you need to upgrade to bit 4
Old 10-25-2018, 16:29   #59 (permalink)
Member: 399404
Thanks Meter: 70
So I have this same tablet and flash this combo- COMBINATION_FA60_T580XXU2AQL2
and everything goes fine but google lock still there..
UNLOCK INSTRUCTIONS:
To reset Pattern lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Press 'Reset Pattern Lock' button.
To reset Google account activation or Samsung reactivation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
3. Select device in ADB settings.
4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Software version: 34.1
Model: SM-T580
PDA version: FA60_T580XXU2AQL2
CSC version:
Phone version:
Product code:
CSC country code:
CSC sales code:
Phone SN: R52JA0A1DSW
IMEI:
HW version:
RF cal date:
Modem board:
Security patch: 2016-05-01
SIM State: NOT_READY
Bypass FRP... OK
Done with Samsung Tool PRO v.34.1
Old 10-26-2018, 16:26   #60 (permalink)
Member: 399404
Thanks Meter: 70
SM-T580 FRP/Combination problem [Answered]
So I flashed it with COMBINATION_FA60_T580XXU4ARJ1 for FRP but now I cant find the right firmware to restore it ...
Can some one point me out.
Page generated in 0.27808 seconds with 8 queries
