steps to unlock Galaxy I9070 first here is my log: Count supported models - 319 Android Version: 2.3.6 Model: GT-I9070 Product Code: GT-I9070HKAATL Phone Version: I9070XXLD1 PDA Version: I9070XXLD1 CSC Version: I9070OXXLD1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Connecting to phone via COM2... Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.7 steps are: 1 - check your phone version. 2 - Root your phone as follow ( exemple : I9070XXLD1): a - open Odin3 v1.83. b - select GT-I9070_EUR_XX_8G_20111220_KL6.pit as pit file. c - select rootkernel.tar in PDA file. d - check only Auto reboot & F.reset time options. e - put your phone in download mode ( V-, Home & Power ). f - install drivers if needed and click Start. g - after reboot do the same with choosing relative tar file ( xxld1.tar for my exemple ). h - wait for phone reboot, then install Superuser from Android-Market. 3 - reboot your phone and connect it ( type *#7284# and choose modem for both options, also use debbuging mode in applictions/devellopment) and install drivers if needed. 4 - open sam_tool 12.7 select propre model and click unlock buttom. 5 - disconnect from usb and connect to S7070 uart cable when ascked. 6 - when unlock done, put a different sim in phone and power on it, when ascked for unlock code just enter : 00000000 Good luck. download files from here: [HOW TO] Samsung Galaxy S I9070 Advance ROOT for most firmwares! - xda-developers |
Nice Info.. Keep It Up... |
AT least someone to share good information THANKS |
Android Version: 2.3.6 Model: GT-I9070 Product Code: GT-I9070HKAVIR Phone Version: I9070XXLD1 PDA Version: I9070XXLD1 CSC Version: I9070VIRLD1 IMEI: Unknown Checking ROOT... TRUE Reading Data From Phone... OK Connecting to phone via COM15... Bypass MSL... Error Done with Samsung Tool ver 12.7 :confused:What is the mistake at this time? |
5 - disconnect from usb and connect to S7070 uart cable when ascked. ......would this be the problem? I throughout usb I worked! |
BINGÓ!!!!!!:D Connecting to phone via COM15...UART cable it here! |
thn alot its working |
hello all, any one can share the direct link for dowload the superuser APK for i9070 pls ? Best Regards, JAVA Good. |
this firmware can't be root why? Selected model: I9070 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-I9070 Android version: 2.3.6 Product code: GT2I9070HKAMSR Phone version: I9070XXLD3 PDA version: I9070XXLD3 CSC version: I9070OXXLD3 IMEI: Unknown Checking Super user right... false Rooting phone, please wait... Done with Samsung Tool |
