04-04-2016, 10:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Age: 38
Member: 307225 Status: Offline Thanks Meter: 59 | Need Help With SM-G925F 6.0.1 ( Patch Certificate ) Code: REPAIR INSTRUCTIONS: Reset EFS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Operation: Patch Certificate Selected model: SM-G925F Software version: 25.0 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXS3DPB3 PDA version: G925FXXS3DPB2 CSC version: G925FBTU3DPB1 CSC country code: UK & IRE CSC sales code: BTU HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.25.0 |
