Old 05-13-2013, 21:37   #1 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
Unlock I9505 only with usb cable and z3x box
you need to put phone in this mode:
*#7284#
UART:
*modem
pda
USB:
modem
*pda
Qualcoom setiings:
MTP
MTP ADB
PTP
PTP ADB
RNDIS DM MODEM
RMNET DM MODEM
*DM MODEM ADB
*#9090#
*1 dm dun over hs usb
2 dm dun over hsic
3dmdun rmnet over hsusb
4dm over uart
5dbg msg on
6dbg msg off
*#0808#
*cp
ap
mtp mtp+adb
ptp
ptp+adb
rndis+dm+modem
rmnet+dm+modem
*dm+modem+adb
1. Goto SETTINGS
2. Click ABOUT DEVICE
3. Trap 7 Times on the BUILD NUMBER.
Once done you should get a message stating "You Are Now A Developer"
Once you have seen the message you can then go back to settings and you should have the option "Developer Options", now you can enable USB Debugging.
log on box:
[21:23:38] LaB. Phones: Selected model: I9505
Selected port: COM21 Qualcomm HS-USB Diagnostics 9004
Selected port speed: 115200
Reading phone info...
Build: M9615A-CEFWTAZM-4.0.17062
Reading security... OK
Searching server... OK
NET lock: #7465625*638*39515027#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
For check lock status: *#7465625#
Done with Samsung Tool v.14.4
Old 06-29-2013, 19:44   #2 (permalink)
Member: 1882718
Thanks Meter: 6
Unfortunately in 4.2.2 it does not work.
Any new workaround?
Old 06-29-2013, 20:15   #3 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
downgrade, and made unlock
Old 07-01-2013, 13:34   #4 (permalink)
Member: 551613
how to downgrade man? i can't find version,only 4.2.2 pls say me were find her?
Old 07-02-2013, 10:42   #5 (permalink)
GSM_PHILIPPINES's Avatar
Member: 1778770
Thanks Meter: 109
sir i have same problem when i type *#7284#
did not show urt modem,,
Old 07-02-2013, 10:59   #6 (permalink)
DUSKnenixs's Avatar
Member: 5169
Thanks Meter: 684
you should downgrde for fisrts release of android version 4.2.2.
The Following User Says Thank You to DUSKnenixs For This Useful Post:
Old 07-03-2013, 01:15   #7 (permalink)
Member: 165154
Thanks Meter: 6
I have same problem too, nathing whem *#7284#
Old 07-03-2013, 09:14   #8 (permalink)
Member: 127430
Thanks Meter: 13
DOWNGRADE NEEDED FOR SURE
You need to put phone in this mode:
*#7284#
UART:
*modem
USB:
*pda
Qualcoom setiings:
*DM MODEM ADB
*#9090#
*4dm over uart
*#0808#
ap
*dm+modem+adb
1. Goto SETTINGS
once you have seen the message you can then go back to settings and you should have the option "Developer
Selected port: COM48 SAMSUNG Mobile USB Serial Port
Calculating... OK
Writing security... OK
Reseting...
Unlock done
Done with Samsung Tool v.14.9
CHECK ALL TIME *#9090# IF dm over uart
Old 07-03-2013, 11:10   #9 (permalink)
haroon454's Avatar
Member: 653398
Thanks Meter: 669
i9505 unlock done
Selected port: COM21 SAMSUNG Mobile USB Serial Port
Calculating... OK
Reseting...
Unlock done
Old 07-05-2013, 09:58   #10 (permalink)
msmobile's Avatar
Member: 253882
Sonork: 100.1585698
Thanks Meter: 242
just dial *#7284# select modem use uart cable and press unlock
Selected port: COM5 Z3X BOX Serial Port
Calculating... OK
Reseting...
Unlock done
Old 07-31-2013, 12:30   #11 (permalink)
Member: 1812723
1. Phone must be powered on.
2. Type *#0808# and select "DM + MODEM + ADB".
3. Choose correct com-port in Port settings.
4. Connect the phone to PC via micro-USB cable.
5. Press "Unlock" button.
Done with Samsung Tool v.14.8
Calculating... OK
Reseting...
Unlock done
Old 07-31-2013, 12:57   #12 (permalink)
Member: 5926
Thanks Meter: 275
another view.
The Following User Says Thank You to Raklm For This Useful Post:
Old 08-15-2013, 10:59   #13 (permalink)
Member: 1898289
Thanks Meter: 39
Question
[QUOTE=DUSKnenixs;9421528]you need to put phone in this mode:
*#0808#
*cp
ap
mtp mtp+adb
ptp
ptp+adb
rndis+dm+modem
rmnet+dm+modem
*dm+modem+adb
In my device if I selece "cp" disapear the next options.
*cp or *ap??
Old 08-16-2013, 12:11   #14 (permalink)
Member: 881000
Sonork: 100.1614181
Thanks Meter: 9
Calculating... OK
Reseting...
Unlock done
The Following User Says Thank You to M4MOHSIN For This Useful Post:
Old 08-16-2013, 13:58   #15 (permalink)
Member: 5926
Thanks Meter: 275
or by uart though z3x box.
Page generated in 0.19670 seconds with 8 queries
