11-30-2010, 03:49 | #16 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1081345 Status: Offline Thanks Meter: 2 | samsung A687 |
The Following User Says Thank You to efrains94 For This Useful Post: |
12-04-2010, 14:22 | #17 (permalink) |
Freak Poster Join Date: Oct 2008 Location: dominican republic
Member: 874313 Status: Offline Sonork: polocell Thanks Meter: 37 | cant unlock a687 by at&t with z3x Count supported models - 214 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&8a0e485&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#6&1452302f&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer |
12-04-2010, 16:31 | #18 (permalink) |
Freak Poster Join Date: May 2005 Location: Kerala (India)
Member: 149154 Status: Offline Sonork: 1605086.100 Thanks Meter: 39 | FOR ME ALSO SAME PROBLEM Count supported models - 217 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&5d02db7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 8.8 |
01-27-2011, 12:31 | #21 (permalink) |
Freak Poster Join Date: Sep 2008 Location: https://t.me/iServer_Panel
Member: 861665 Status: Offline Thanks Meter: 21 | Count supported models - 217 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.8 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&15f3d041&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:48) Freeze code: 20248363 NET lock: #7465625*638*58285051# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.8 |
02-19-2011, 00:11 | #22 (permalink) |
Temporary banned !! Join Date: Nov 2008 Location: Colombia
Member: 911276 Status: Offline Sonork: INFANTERIA Thanks Meter: 16 | tested 1000% Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&94ae1cb&0&3#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:41) Freeze code: 58184924 NET lock: #7465625*638*92826158# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 greetings infanteria |
02-21-2011, 17:12 | #25 (permalink) |
Member: 911276 Status: Offline Sonork: INFANTERIA Thanks Meter: 16 | |
05-10-2011, 11:13 | #26 (permalink) |
Insane Poster Join Date: Mar 2009 Location: philippines
Member: 991791 Status: Offline Thanks Meter: 15 | 1. Select A797 model 2. Press 1 + 0 key and connect usb cable 3. Press Unlock SP Tested by me Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&2eea3905&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:26) Freeze code: 57306842 NET lock: #7465625*638*15393850# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 thanks!!!!!!!!! it's really works 100% Last edited by markjohn73; 05-10-2011 at 11:18. |
08-11-2011, 17:07 | #27 (permalink) |
No Life Poster Join Date: Oct 2007
Member: 605126 Status: Offline Sonork: 100.1617907 Thanks Meter: 297 | thx bro i unlock toooo.. logs.. Count supported models - 214 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 8.6 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 8.6 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 8.6 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&3a26cb6&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:08) Freeze code: 93928031 NET lock: #7465625*638*05907393# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.6 |
08-19-2011, 17:34 | #29 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ghana
Member: 320120 Status: Offline Thanks Meter: 98 | with several trials i finaly made it: Count supported models - 223 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Select COM port Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- Select COM port Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&340a0f05&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... Error Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&340a0f05&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:06) Freeze code: 91371581 NET lock: #7465625*638*26286208# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
