08-25-2011, 15:23 | #31 (permalink) |
No Life Poster Join Date: Jul 2006 Location: ghana
Member: 320120 Status: Offline Thanks Meter: 98 | Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&2eea3905&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:54) Freeze code: 74208502 NET lock: #7465625*638*39680379# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
08-30-2011, 11:27 | #32 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#6&14b4c0a5&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:00) Freeze code: 84962058 NET lock: #7465625*638*73959517# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
09-01-2011, 01:33 | #33 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Los Angeles, CA
Member: 1081371 Status: Offline Thanks Meter: 720 | Here is my Log!! No answer from phone Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#7&1e82c7b9&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:51) Freeze code: 64139426 NET lock: #7465625*638*24740308# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
10-03-2011, 09:56 | #34 (permalink) |
No Life Poster Join Date: May 2006 Location: West Jerusalem
Member: 280342 Status: Offline Thanks Meter: 73 | otocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:58) Freeze code: 70253571 NET lock: #7465625*638*79028614# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 \\ |
10-26-2011, 18:04 | #35 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Unknown
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | Select COM port Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&ea588c7&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:22) Freeze code: 04147579 NET lock: #7465625*638*28029051# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
11-02-2011, 03:15 | #36 (permalink) |
Freak Poster Join Date: May 2008 Location: montevideo-URUGUAY Age: 37
Member: 774392 Status: Offline Thanks Meter: 18 | for me work key "1" + KEY "SYM" Press 1 + 0 and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + 0 and connect phone by cable<<==== NO WORK FOR ME Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&8a0e485&0&1#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:32) Freeze code: 16085958 NET lock: #7465625*638*41914736# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 BR |
11-30-2011, 19:13 | #37 (permalink) |
Junior Member Join Date: Aug 2005 Age: 48
Member: 168512 Status: Offline Thanks Meter: 0 | Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&29c7aec0&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&29c7aec0&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&29c7aec0&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&29c7aec0&0&1# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK No answer Done with Samsung 3G tool ver 9.4 Done with Samsung 3G tool ver 9.4 plz can someone help me the above is what i keep getting nomatter what i do.wht next should io do plz |
12-01-2011, 21:48 | #39 (permalink) |
Junior Member Join Date: Jun 2007
Member: 530467 Status: Offline Thanks Meter: 1 | hola acavo de comprar la zx3 combo y estoy intentando desbloquear el samsung sgh-a687 de att, me queda claro como hacerlo usando el samsung tool3g v8.6 ya lo descarge y seleccionando el modelo a979 pero mi problema es que no me abre el programa me aparece la primer pagina del mismo pero no abre espero alguien me pueda ayudar con eso se los agradecere mucho bye |
12-08-2011, 09:25 | #40 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 596251 Status: Offline Thanks Meter: 33 | Z3x S5600 Unlocking Count supported models - 223 Searching USB Device... not found Done with Samsung 3G tool ver 9.4 Searching Samsung USB interface... not found ----------------------------- No answer from phone Done with Samsung 3G tool ver 9.4 Searching USB Device... not found Done with Samsung 3G tool ver 9.4 Searching USB Device... detected (COM12) Reading Phone Info... OK Model: GT-S5600 Factory SW: S5600BVIH3 CountryCode: ORA UniqueNumber: 80360000226677 MemoryPhone: K5R2G1GACC(S5600)S SW: S5600BVIH3 IMEI: 35631503742892/9 Reading SysInfo... OK Searching server... OK Unlocking... OK Done with Samsung 3G tool ver 9.4 |
12-17-2011, 16:13 | #42 (permalink) |
Member: 1274304 Status: Offline Sonork: 100.1617965 Thanks Meter: 195 | Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&ea588c7&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:01:11) Freeze code: 20209206 NET lock: #7465625*638*84759195# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
12-19-2011, 14:23 | #43 (permalink) | |
Member: 774392 Status: Offline Thanks Meter: 18 | Quote:
BR | |
04-21-2012, 10:11 | #45 (permalink) |
No Life Poster Join Date: May 2010 Location: india
Member: 1300517 Status: Offline Sonork: 100.1601031 Thanks Meter: 104 | with out battry do unlock work 100% Count supported models - 223 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... not found Done with Samsung 3G tool ver 9.4 Press 1 + message key and connect phone by cable Waiting for SE USB Device... OK Detected:\\?\usb#vid_0bdb&pid_100e#5&2d753ade&0&2# {a5dcbf10-6530-11d2-901f-00c04fb951ed} Opening Port... OK Flash ID900 Protocol:0401 Sending Loader 1... OK Sending Loader 2... OK Sending Loader 3... OK Sending Loader 4... OK Reading Data... OK Calculating stage 1... OK Calculating stage 2... OK Calculating codes... OK (time - 00:00:28) Freeze code: 03824686 NET lock: #7465625*638*58270592# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 9.4 |
The Following User Says Thank You to G.G For This Useful Post: |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
