01-29-2010, 21:25 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1153599 Status: Offline Thanks Meter: 0 | Unlock/Unlocking Samsung S8300 with Z3X Box - Need Help! Can anyone please help me on the following: I want to know which cable I need to use, it says mini USB. Does that mean I can use the normal phone USB cable for this phone? or is there some other special cable, if so where can I get it from and does it have some code name. Also can you please kindly show me the full Instructions/Steps that are required to unlock this phone by using the Z3X Box. Any help from someone would be greatly appreciated. Many Thanks. |
01-30-2010, 05:30 | #3 (permalink) | |
Junior Member Join Date: Feb 2004
Member: 54646 Status: Offline Thanks Meter: 0 | Quote:
07-13-2010, 02:59 | #5 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Quote:
then press 9+power key on ur mobile Now ur mobile go to download mode Now u connect Micro usb cable on ur pc or connect it on software box usb socket now ur pc has recogonised ur mobile then its need to install driver after install it shows Your new hardware is ready for use Now go to samsung 3g tool then click just "unlock" gud luck,happy unlocking...... | |
The Following 2 Users Say Thank You to ..::MOBILES::.. For This Useful Post: |
07-14-2010, 09:43 | #6 (permalink) | |
Freak Poster Join Date: Jun 2006
Member: 290273 Status: Offline Thanks Meter: 9 | Quote:
micro and mini usb are different in size micro usb is i.e ca101 mini usb is i.e dke2 anyway you unlock this model in download mode correct??? as thats what you have put??? stemo | |
07-23-2010, 15:38 | #7 (permalink) |
Freak Poster Join Date: Nov 2009 Location: U.K (leeds)
Member: 1157490 Status: Offline Sonork: 100.1638346 Thanks Meter: 74 | you can unlock it other way as well. 1.Reset phone with*2767*3855# 2.put in qualcom mode *#782872# 3.put usb(no matter mini or normal size) in Z3X box com port,it'll search & install drivers automatically. 4.select com portcom 202zte diagnosticinterface 6000....) 5.press unlock sp 6.wait untill procedure finished. 7.put original sim in phone and power it on. 8.put netlock code,#7465625*638*........ unlock done 100% tested. enjoy |
The Following 5 Users Say Thank You to champions1 For This Useful Post: |
08-26-2010, 18:36 | #9 (permalink) |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | ok now it ok but should tape this , type *#7465625# and do sp unlock see this : Reading security... error! (Insert SIM or type *#7465625#) Searching Qualcomm USB interface... detected (COM13) Model: S8300 IMEI: 35627603157336 SW: S8300BOIH3 Reading data from phone... OK Reading security... OK Calculating codes... OK (time - 00:00:09) Freeze code... 02525290 NET lock code... 00000000 Sub lock code... 00000000 SP lock code... 00000000 CP lock code... 00000000 SIM lock code... 12369874 Activa code... 12369874 How to enter codes: NET: #7465625*638*00000000# Sub: #7465625*782*00000000# SP: #7465625*77*00000000# CP: #7465625*27*00000000# SIM: #7465625*746*12369874# |
10-25-2010, 06:00 | #10 (permalink) | |
Freak Poster Join Date: Jul 2006 Age: 45
Member: 316292 Status: Offline Thanks Meter: 102 | Quote:
12-21-2011, 14:18 | #11 (permalink) | |
Insane Poster Join Date: Nov 2009
Member: 1154494 Status: Offline Thanks Meter: 3 | Unlocked successfully Samsung S8300v Quote:
1.Reset phone with*2767*3855# 2.put in Samsung mode *#726872# 3.put usb(no matter mini or normal size) in Z3X box com port,it'll search & install drivers automatically. 4.select com port - normally it will automatically select the z3x box 5.Unlock sp method - Direct 6.press unlock sp 7.wait until procedure finished. 8. switch on phone check lock status: *#7465625# NET lock should be OFF unlock done 100% tested Picture help Cell Care Mobiles | |
03-21-2012, 14:49 | #12 (permalink) |
Major Poster Join Date: Feb 2010
Member: 1242652 Status: Offline Sonork: mdobrais Thanks Meter: 9 | Searching USB Device... detected (COM8) Reading Phone Info... OK Model: GT-S8300 Factory SW: S8300BVIC1 CountryCode: ORA UniqueNumber: 70120000451873 MemoryPhone: K5R2G1GACC(S8300)S SW: S8300XEIC4 IMEI: xxxxxxxxxxxxxxx Reading SysInfo... OK Searching server... error (Maybe OLD Security) Change Mode to Qualcomm and Try Again Done with Samsung 3G tool ver 9.4 where is the problem? but in Qualcomm its not find Qualcomm mode |
07-11-2012, 09:12 | #13 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Sri lanka Age: 43
Member: 454011 Status: Offline Sonork: 1656095 Thanks Meter: 147 | Quote:
I have same error help me z3x team argent | |
08-08-2013, 08:14 | #14 (permalink) |
Junior Member Join Date: Mar 2011 Location: devdaha khaireni nepal
Member: 1527882 Status: Offline Thanks Meter: 3 | Selected model: S5292 Selected port: COM3 Z3X Serial Port Selected port speed: 921600 Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 11F000FF Reading security... OK Rebooting phone... OK Now connect phone to UART cable Checking phone at COM3... timeout Done with Samsung Tool v.15.1 |
Samsung s8300 successfully unlock with z3x box | top man | Z3X-Team Products | 0 | 03-21-2010 16:53 |
z3x box need help | shawgsm | Z3X-Team Products | 6 | 12-23-2009 11:55 |
How to unlock Samsung S8300 with Z3X-team | hoangtruongson | Z3X-Team Products | 2 | 05-27-2009 07:25 |
Unlock your softbank phone with z3x-box! | blang | Main Sales Section | 0 | 03-24-2009 19:34 |
problem with my box! need help | .:ramtelecom:. | MT-BOX | 6 | 07-13-2007 14:42 |
