04-16-2017, 13:57 | #1 (permalink) |
No Life Poster Join Date: Jan 2014 Location: africa mali
Member: 2098907 Status: Offline Thanks Meter: 154 | J320fn sending hiden failed need help Operation: Flash Selected model: SM-J320FN Software version: 27.8 File analysis... Ok Total file size: 0x80C906E4 (2060 Mb) Searching USB Flash interface... COM39 detected Setup connection... Ok Reading PIT from phone... Ok Sending spl.img... Ok Sending sboot.bin... Ok Sending sboot2.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending SPRDCP.img... Ok Sending SPRDGDSP.img... Ok Sending SPRDLTEDSP.img... Ok Sending SPRDWDSP.img... Ok Sending PM_sharkl_arm7.bin... Ok Sending nvitem.bin... Ok Sending cache.img... Ok Sending hidden.img... error timeout Done with Samsung Tool PRO v.27.8 |
04-16-2017, 15:07 | #4 (permalink) |
Member: 2098907 Status: Offline Thanks Meter: 154 | with latest version 28.1 same error FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-J320FN Software version: 28.1 File analysis... Ok Total file size: 0x80C906E4 (2060 Mb) Searching USB Flash interface... COM39 detected Setup connection... Ok Reading PIT from phone... Ok Sending spl.img... Ok Sending sboot.bin... Ok Sending sboot2.bin... Ok Sending boot.img... Ok Sending recovery.img... Ok Sending system.img... Ok Sending SPRDCP.img... Ok Sending SPRDGDSP.img... Ok Sending SPRDLTEDSP.img... Ok Sending SPRDWDSP.img... Ok Sending PM_sharkl_arm7.bin... Ok Sending nvitem.bin... Ok Sending cache.img... Ok Sending hidden.img... error timeout Done with Samsung Tool PRO v.28.1 |
04-16-2017, 21:59 | #5 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Quote:
