Worlds first SM-J710f repair and patch network [Done] WOW WOW j710f imei write and patch done LOve U Z3x full network muawaaaaaaaa Software version: 27.4 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZKUSER Phone version: J710FXXU1APG2 PDA version: J710FXXU1APG2 CSC version: J710FOXY1APG2 CSC country code: Russia CSC sales code: SER HW version: MP 0.400 Phone SN: RZ8HA1BA1YK Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: 20161019 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done Done with Samsung Tool PRO v.27.4 |
Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-J710F Software version: 27.4 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDUXSG Phone version: J710FXXU1APCD PDA version: J710FXXU1APE1 CSC version: J710FOJV1APE1 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RZ8H80CL95K Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: 20160806 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... error Done with Samsung Tool PRO v.27.4 this err how to solve......... |
pls share nvm and efs backup from working phone pls it will be big help |
Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: Phone version: J710FXXU1APH4 PDA version: J710FXXU1APLM CSC version: J710FOJV1APJ1 CSC country code: KSA CSC sales code: KSA HW version: Phone SN: RF8HC02232N Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (decompress error) Done with Samsung Tool PRO v.27.7 Please help me to back to normal imei now my imei is 00000000000001 but baseband is ok |
it was many time done Operation: Patch Certificate Selected model: SM-J710F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDDXSG Phone version: J710FXXU1APCD PDA version: J710FXXU1APD7 CSC version: J710FOJV1APD7 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RF8H635MN8B Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: 20160630 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done or nv file SM-J710F_RF8H635MN8B_23-1-2017_20-54-32_nv_data - Download - 4shared |
j710f imei 0001 [QUOTE=farukpdm;12308713]it was many time done Operation: Patch Certificate Selected model: SM-J710F Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-J710F Android version: 6.0.1 Product code: SM-J710FZDDXSG Phone version: J710FXXU1APCD PDA version: J710FXXU1APD7 CSC version: J710FOJV1APD7 CSC country code: UAE CSC sales code: XSG HW version: MP 0.300 Phone SN: RF8H635MN8B Chip name: EXYNOS7870 Modem board: SHANNON315 RF cal date: 20160630 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Rebooting phone... Ok Patching CERT check... done or nv file SM-J710F_RF8H635MN8B_23-1-2017_20-54-32_nv_data - Download - 4shared[/QUOTE I tried your file but same issue |
2>Install Latest Combination File 3> After Set Open Check imei 4> Now Install Official Firmware Its Tested Solouation From Me 100% 1 April 2017 Scurity |
BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. (Note, that the cert file for this model is unique. You can write cert, wich is readed from this device exactly.) Opération:Write CERT Modèle sélectionné:SM-J710F Version du logiciel:29.6 En attendant le périphériqueADB... Ok Lecture d'information du telephone... Modèle: SM-J710F Android version: 7.0 Code du produit: Version du telephone: PDA version: J710FXXU3BQI8 CSC version: J710FODD3BQI8 SCC code de pays: India CSC code de vente: INS HW version: Téléphones SN: RF8J721QLRF Nom de la puce: EXYNOS7870 Prise modem: Security patch: 2017-08-01 RF cal date: IMEI: Vérification de droit de super utilisateur... vrai La lecture des données deNV... Ok VérificationNV data ... Ok Lecturedata... Ok Détection MODEM... Ok LectureMODEM... Ok Calcul... Ok RédactionzTool... Ok InitialisationzTool... Ok CourirzTool, s'il vous plaît patienter... Démarrer... Ok Initialisation... Ok Générer et vérifier client la preuve... Ok Vérifier la preuve par le client... Ok Lecture de données... erreur (1 19) InitialisationzTool... Ok CourirzTool, s'il vous plaît patienter... Démarrer... Ok Initialisation... Ok Générer et vérifier client la preuve... Ok Vérifier la preuve par le client... Ok Lecture données du Téléphone... erreur (0) Essayez modem downgrade si possible Fait avecSamsung Tool PRO v.29.6 |
plz help me for write cert |
its Not working in 7.0 plz solve this checking super user right...true 7.0 is not supported |
J710F after patch certificate handsset baseband unknown witre certificate and efs file baseband same Write last version Handset Touch Not work please any solution |
help me guys Operation: Info Selected model: SM-J710F Software version: 33.5 Searching Samsung modem... detected COM32 Reading phone info... Model: SM-J710FN AP version: J710FXXU5BRC2 CSC version: J710FOJK5BRC1 CP version: J710FXXU5BRC4 Product code: ILO Phone SN: RF8HB0ZJT9K IMEI: 000000000000000 IMEI2: 000000000000000 Unique number: CAJ039B42F0DDA3 Reading IMEI... OK IMEI: 000000000000000 (SIGN: UNKNOWN) IMEI 2: 000000000000000 (SIGN: UNKNOWN) Done with Samsung Tool PRO v.33.5 Waiting ADB device... OK Reading phone info... Model: SM-J710F Android version: 7.0 PDA version: J710FXXU5BRC2 CSC version: J710FOJK5BRC1 Phone version: J710FXXU5BRC4 Product code: CSC country code: ISRAEL CSC sales code: ILO Phone SN: RF8HB0ZJT9K IMEI: 000000000000000 HW version: RF cal date: Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-04-01 Boot Warranty bit: 0 Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) This solutions Done with Samsung Tool PRO v.33.5 |
hello people can someone tell me how to get the imei of 2 and for 1 to have 2 imei same in g955fd |
Repair imei g955fd imei cloned hello people can tell me how to get the imei of 2 and put in 1 in case the imei get cloned g955fd Sorry for the errors in the writing I'm using GOOGLE TRANSLATOR |
