z130 unlock plz to unlock z130 i av some pb here is the log Searching Samsung USB interface... not found Searching Qualcomm USB interface... not found Unlock as COM MSL2... error ,plz can somebody tell me how to unlock this fon with z3x or other? |
Qualcom mode method (only usb): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB part of 2in1 cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes or Direct. 6. Press Unlock SP button. Samsung mode method (2in1 cable): 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Samsung mode 3. Connect 2in1 cable, setup drivers. 4. Choise port of RJ45 connector in port settings 5. Choise unlock method: Read codes or Direct. 6. Press Unlock SP button. |
i turned on my z130, without sim and put in this code: *#197328640#, to put it into samsung mode, but it just says "emergency calls only" when i put in the code. i also put an original sim in the phone and then put in the mode and press DIAL button and then it just says "unknown command". how cant i put it into Samsung mode? did i enter the code correctly? plz help me |
samsung z130 unlock Quote:
Conect tel. with LG 7050 rj45 cable and press "Unlock" It work perfect !:cool: |
spamm |
yes good for me thanks |
i try unlocking my samsung z130 with z3x but it is showing no answer, please i need help |
In Samsung Tool Pro doesn't appear that model, the SGH-Z130, only Z100/105/107/110/140/170, must I use one of those? |
Enviado desde mi EVA-L09 mediante Tapatalk |
