01-22-2017, 11:29 | #1 (permalink) |
Product Manager Join Date: Mar 2014 Location: Bangladesh Age: 30
Member: 2142580 Status: Online Thanks Meter: 1,214 | SM-G570F unlocking error Modem Downgrade? Anyone ever done it Waiting ADB device... Ok Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZDDKSA Phone version: G570FXXU1APL1 PDA version: G570FXXU1APIB CSC version: CSC country code: CSC sales code: HW version: MP 0.500 Phone SN: R28HB03L1TK Chip name: EXYNOS7570 Modem board: SHANNON305 RF cal date: 20161101 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post: |
01-22-2017, 13:47 | #2 (permalink) | |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | Quote:
The Following User Says Thank You to kamrolhasan For This Useful Post: |
01-22-2017, 13:58 | #3 (permalink) | |
Member: 2142580 Status: Online Thanks Meter: 1,214 | Quote:
lucking this > Checking Super user right... true | |
01-22-2017, 15:04 | #4 (permalink) | |
01-30-2017, 13:32 | #5 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: GHANA Age: 28
Member: 2373688 Status: Offline Thanks Meter: 57 | Quote:
please is the firmware pre-rooted? | |
The Following User Says Thank You to maxwell12 For This Useful Post: |
06-05-2017, 14:48 | #9 (permalink) |
Freak Poster Join Date: Mar 2015 Location: kushtia Age: 31
Member: 2356568 Status: Offline Sonork: 1663093 Thanks Meter: 126 | 1OO% SOLUTION http://forum.gsmhosting.com/vbb/f453...phone-2231320/ |
The Following User Says Thank You to gsm_rabby For This Useful Post: |
06-05-2017, 15:14 | #10 (permalink) | |
No Life Poster Join Date: May 2016 Location: GSM-Forum
Member: 2574306 Status: Offline Thanks Meter: 343 | Quote:
06-12-2017, 01:12 | #12 (permalink) | |
Freak Poster Join Date: May 2009 Location: Bangladesh
Member: 1024093 Status: Offline Thanks Meter: 87 | Quote:
http://forum.gsmhosting.com/vbb/f453.../#post12541935 | |
06-12-2017, 11:22 | #13 (permalink) | |
Junior Member Join Date: Nov 2014 Location: dhaka,bangladesh Age: 30
Member: 2292325 Status: Offline Thanks Meter: 11 | Quote:
BIG TNX BRO,,,,,this way done for me | |
The Following User Says Thank You to nishubd For This Useful Post: |
08-23-2017, 10:10 | #14 (permalink) |
Insane Poster Join Date: Feb 2017 Location: Gazipur
Member: 2680150 Status: Offline Thanks Meter: 10 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Unlock Selected model: SM-G570F Software version: 29.0 Waiting ADB device... OK Reading phone info... Model: SM-G570F Android version: 6.0.1 Product code: SM-G570FZDDKSA Phone version: G570FXXU1AQC1 PDA version: G570FXXU1AQC2 CSC version: G570FOJV1AQC2 CSC country code: KSA CSC sales code: KSA HW version: MP 0.500 Phone SN: R58J52XR7FT Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-03-01 RF cal date: 20170513 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 23) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.29.0 |
08-24-2017, 10:51 | #15 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... error Security damaged (4 23) Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.29.1 same problem facing |
