Old 03-05-2018, 02:59   #1 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
G955U Unlock done but not unlocked
  UNLOCK INSTRUCTIONS:
    Unlocking with original MSL code:
    Warning! Knox warranty must be active (0x00)!
    If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
  1. Phone must be powered on.
  2. Type *#0808# and select 'DM+ACM+ADB'.
  3. Run dialer and type *#0*# (service mode will appear).
  4. Connect the phone to USB cable, choose correct COM port in port settings.
  5. Press 'Unlock' button.
  6. Paste MSL code in new opened window and press 'OK'.
    Unlocking using Server:
  1. Power on the phone.
  2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
     go to 'Settings'-'Developer options' and enable 'USB debugging'.
  3. Connect the phone to PC with USB cable, install drivers if needed.
  4. Select device in ADB settings.
  5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear.
    (Login and password will be saved as default after first input and can be changed in settings)
    Reading codes using sever:
  5. Press 'Read Codes via server' button, write your login and password in window if it will appear.
    (Login and password will be saved as default after first input and can be changed in settings.)
Operation: Read Codes via Server
Selected model: SM-G955U
Selected port: COM8 USB Serial Port
Software version: 30.8
Checking Login and Password... OK
Ballance: 30 crd.
You have 30 credit(s) left. This operation takes 5 credits.Continue?  Yes
Waiting ADB device... OK
Reading phone info...
Model: SM-G955U
Android version: 7.0
Product code: SM-G955UZKATMB
Phone version: G955USQS2BQL1
PDA version: G955USQS2BQL1
CSC version: G955UOYN2BQL1
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone SN: R28J40QKLNN
Chip name: MSM8998
Modem board: MSM8998
Security patch: 2017-12-01
RF cal date: 2017.04.08
IMEI: 355980080846011
Waiting for device to become ready... OK
Initialization zTool... OK
Running zTool, please wait...
Start... OK
Initialization... OK
Generate and check client proof... OK
Verify proof by client... OK
Reading data from phone... OK
Searching Ramdump interface... COM6 detected
Calculating... OK
Searching server... OK
Waiting for server answer... OK
Freeze code: 49405848
NET lock: 42819082
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.30.8
Old 03-05-2018, 03:59   #2 (permalink)
Member: 2312734
Thanks Meter: 8
Ballance: 30 crd.
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Start... OK
Calculating... OK
NET lock: 42819082
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
You did read codes via server... and that device is tmobile, you have to use the option that says unlock tmb...
Sent from my SM-G950U using Tapatalk
Old 03-05-2018, 07:30   #3 (permalink)
Member: 453916
Sonork: 100.1620840
Thanks Meter: 246
thanks @gilbernjq
support can my 5 credit return it back?
Operation: Unlock
Ballance: 25 crd.
You have 25 credit(s) left. This operation takes 10 credits.Continue?  Yes
Model: SM-G955U
CSC sales code: TMB
HW version: REV1.0
Chip name: MSM8998
Start... OK
Rebooting to upload... OK
Calculating... OK
Start... OK
Rebooting phone... OK
Unlock done
Page generated in 0.18419 seconds with 9 queries
