Old 05-28-2015, 20:41   #211 (permalink)
Member: 1816528
Originally Posted by wutangclan33 View Post
hei sir i want to ask you...
at this case, did you wipe efs first sir...?
or you just got to click unlock?
It is a direct unlock, no need to wipe efs/write cert. if its a S6/S^edge needs to be rooted with usb debugging activated and press unlock.
The Following User Says Thank You to Michael443 For This Useful Post:
Old 05-28-2015, 22:46   #212 (permalink)
Member: 87188
Thanks Meter: 229
Simply root and unlock.
The Following User Says Thank You to Pufi164 For This Useful Post:
Old 05-29-2015, 11:56   #213 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 74
21.1 tool cert patch after null imei. not fixed
Old 05-29-2015, 15:18   #214 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
Which model? I've repaired lot of S7390L and worked fine. By the way version 21.2 was released already.
Read this, http://forum.gsmhosting.com/vbb/show....php?t=1139639 helps us all to help you all.
Old 05-29-2015, 16:31   #215 (permalink)
Member: 2280998
Originally Posted by zozodouce View Post
yes you can and it's free for you. just update your shell and
run hardware wizard to activate pro.
thank you brother >>> but after update my shell how can i active the pro acount?
Old 05-30-2015, 08:18   #216 (permalink)
joel_3mo's Avatar
Member: 2061381
Sonork: 100.1673769
Thanks Meter: 129
Go to shell > settings an hardware tools > run hardware wizard > add new activations > select Samsung Tool PRO > next > finish
All done, now you can work with latest soft.
The Following User Says Thank You to joel_3mo For This Useful Post:
Old 05-30-2015, 20:50   #217 (permalink)
Member: 2280998
thank you brother but the "add new activations" option isn't active , what the problem?
Old 05-30-2015, 20:53   #218 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,654
Contact with resellers and buy activaion
Old 05-31-2015, 14:34   #219 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 74
oh sorry for i9300 imei repair not fixed. ok but not have changes for i9300 in 21.2 release.
Old 05-31-2015, 16:04   #220 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
http://forum.gsmhosting.com/vbb/f453...rters-1139639/
Page generated in 0.18150 seconds with 8 queries
