Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 04-19-2009, 09:48   #1 (permalink)
mitch_md3's Avatar
Member: 187319
Sonork: 100.1593798
Thanks Meter: 75
BlackBerry 8220 successfully Unlocked Via Code ONLY (w/procedure)
wanna share BlackBerry 8220 Pearl Flip T-Mobile successfully unlock via Code only..
here's the right procedure..
How to turn Wireless Mode Off:
1. Scroll to (Turn Wireless Off.)
2. Press Select.
3. Wireless Mode will turn off.
How to Unlock the device:
1. insert any sim card
2. Go to Menu
3. Go to Setting
4. Press Advance Option
5. Press Sim Card
( it shows nothing)
6. Type meppd
it shows 5 Personalization:
Sim -- Disable
Network-- Active
Network Subset -- Disable
Service Provider -- Disable
Corporate -- Disable
7. hold shift + alt then type mepp2
8. now it shows "Enter Network MEP Code"
9. inter your CODE.
10. BlackBerry now is Unlocked
WARNING: The Wireless Mode MUST be OFF before performing the given SIM
Unlock instructions in order to avoid causing the device from becoming
defective.
and the prof..
anyways... thanks to nonoyxp for extra help and GSMFtaher for providing the working codes..
The Following 6 Users Say Thank You to mitch_md3 For This Useful Post:
Blackberry - anyway to unlock via Imei and MEP only? Seedy FuriousGold 3 02-16-2010 11:55
KP107 successfully unlocked via code reading. Haltec VygisToolbox 2 01-21-2010 15:33
Ku990 Viewty Successfully Unlock Via Codes clearcom Gsmfather The Wholesale Unlocking Database 4 02-26-2008 13:10
Page generated in 0.17253 seconds with 9 queries
