Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 09-13-2013, 18:00   #1 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
Need Refund!
I can't seem to understand why are you saying wrong carrier? First when I check Carrier & Simlock, it says US AT&T, Puerto & Virgin Islands. I then submitted the another request, you came back and said "Block, Barred". The last I requested #739263 APAC - iPhone 3G/3GS/4/4S/5 (Barred and Not Found)
Now you're saying "Wrong Carrier" after 1 week without refund?. I ordered it thru APAC because that's the only Barred/Not Found" there in your listing.
What exactly is the carrier here? Your system originally shows US AT&T, Puerto Rico & US Virgin Islands.
* * * * NEED REFUND * * * *
Thanks!
Old 09-14-2013, 08:45   #2 (permalink)
Member: 1786546
Sonork: 100.555
Thanks Meter: 394
Order ID - 739263
IMEI 012850005667682
Unlock Code WRONG CARRIER
Status
API Reference ID
Order On 09/03/2013 04:37
this was por the apac
USA AT&T 1-24 Hours - iPhone 3G/3GS/4/4S/5
Order ID - 735680
Reason NONAT&T/Blacklisted
Order ID - 771751
Unlock Code MODEL: iPhone 4 16GB Black
IMEI: 012850005667682
SERIAL: 7U123DVAA4S
HW WARRANTY: Out of Warranty
PHONE SUPPORT: No phone support
ACTIVATION STATUS: YES
LAST ACTIVATED SIM: AT&T - United States USA
ORIGINAL CARRIER: US AT&T Puerto Rico and US Virgin Islands Service Policy
Coverage Status: Out Of Warranty (No Coverage)
Estimated Purchase Date: 07/28/10
Replacement devices:
Serial ######## IMEI ######## Type Replacement Date
7U123DVAA4S 012850005667682 Active 08/16/11
75030ZCNA4S Replaced 08/26/10
7T03017TA4S 012416003840448 Original 08/26/10
these are the orders from you for the same imei
1. carrier check returns it as usa att is ok
2. you place on usa att. it is rejected as nonatt / blacklisted
so the problem is done who said you to try it on the apac service
if you dont know what it is you must ask and use we cannot refund the wrong carriers
Old 09-14-2013, 21:16   #3 (permalink)
Member: 1227040
Sonork: 100:1654728
Thanks Meter: 55
You knew it was wrong carrier but you accepted the request so you can keep the money without satisfying your customer.. What kind of service is that? I am a noob in this kind of stuff so could you just cut me a slack here. I learned something new now.
Also, if it is blacklisted/barred, is there a way we can obtain unlock for this kind of phone status? Put a note in your website so others don't make the same mistake!
Page generated in 0.12349 seconds with 8 queries
