06-20-2012, 14:34 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: DHAKA
Member: 808657 Status: Offline Sonork: 100.1590300 Thanks Meter: 112 | Iphone 4 continue dfu mode I try to restore custome firmware 5.1.1 error 1601. i use ireb software .but same error ..1601 any body help me................................ |
06-20-2012, 15:10 | #4 (permalink) |
Major Poster Join Date: Dec 2010 Location: Dhaka, Bangladesh
Member: 1480529 Status: Offline Sonork: 100.1612553 Thanks Meter: 12 | IPHONE 4 CONTINUE DFU MODE I try to restore custome firmware 5.1.1 error 1601. i use ireb software .but same error ..1601 any body help me................................ check the battery power then restore original firmware 5.1.1 |
06-20-2012, 15:36 | #6 (permalink) |
No Life Poster Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks Meter: 346 | iphone dfu mode friend first make your phone is in dfu mode later fist jailbreak your set instructions 1. run latest ireb the last version 2. jailbrek with redsnow 9.10b1, or 9.10.b2, or with 9.10b3 3.connect itune and load os thats it is if helps push thanks |
The Following User Says Thank You to R.Nasir.Ali For This Useful Post: |
06-20-2012, 15:48 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | Re-install all apple stuff(remove all apple things and install again), if won't work restore that iphone on other machine (i could say you to format and do a clean install of windows, but other more cleanner machine could do it). Use tinyumbrella to kick out of recovery does not work? If you are using a custom firmware, 1st execute tinyumbrella, 2nd start tss server and 3rd start itunes and recover iphone to the custom firmware. br Last edited by Desirat; 06-20-2012 at 15:54. |
06-21-2012, 08:51 | #11 (permalink) |
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks Meter: 346 | dfu mode 1601 is communication error that means your phone is not contacted properly service the port with thinner brush any how try charge your battery phone here are some tools which will be helpful for you use the ireb which is in the folder try to jailbreak with the same version os you want to load first before loading os 1. ireb 2. jailbreak 3. load os thanks |
06-21-2012, 09:23 | #12 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
connect ur cable with direct usb(not front usb) and try to restore with ios 5.1.1 u got ur mobile seccessful restore tested by | |
06-23-2012, 13:51 | #15 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: Cambodia,Battambang Province
Member: 1370639 Status: Offline Thanks Meter: 41 | Quote:
pls change host and Restart your computer ....... check version itune and start restore again (if your phone origenal restore with origenal firmware)but lock use Custom !!! try,,,,,,,,,,if you problem plx post again!!! | |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
All 4 locks on 6110 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-19-2010 02:44 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
