Old 02-19-2015, 15:53   #1 (permalink)
Member: 2220270
Thanks Meter: 8
iphone 4 can't activate error [0xE8000004] need help please
it was just hang and ios 7.04.
wifi not work
so i upgrade but try activate too many times with different pc same
need help
Old 02-19-2015, 16:11   #2 (permalink)
janzir's Avatar
Member: 1726910
Sonork: 100.1623945
Thanks Meter: 41
I have sam problem
The phone was working fine before i restored the firmware
Nb: wifi was grey
Sent from my iPhone using Tapatalk
Old 02-19-2015, 16:18   #3 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
Connect iPhone , launch tinyumbrella and look for saved shsh .
If you are lucky , you'll be able to downgrade , then do a normal update to iOS 7.1.2 ( not a restore ) .
__________________
Regards,
Mehdi
The Following User Says Thank You to loca|host For This Useful Post:
Old 02-23-2015, 15:12   #4 (permalink)
Member: 2220270
Thanks Meter: 8
Thanks sir
i check properly there is wifi main supply [+] supply. now set is ok.
another problem come. if i reset network setting wifi work arround 5 min then
automatic wifi shut down. i restore again but same. how to solved this problem.
Old 02-24-2015, 10:14   #5 (permalink)
Member: 813803
Thanks Meter: 120
same problem anyone have a solution?
Old 02-24-2015, 10:33   #6 (permalink)
Member: 1420702
Sonork: 100.1611226
Thanks Meter: 12
bro chk wifi if not ok only downgrade now active
zafar
Page generated in 0.11124 seconds with 8 queries
