Old 02-12-2015, 11:46   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
iphone 4/4s icloud remove
hello
i have an iphone 4 ,phone is active but inside no have any icloud id ,i check this phone imei manually ,report is find my iphone is on ,then i put my own apple id and pass and turn off find my iphone but still this phone showing find my iphone is on .phone problem is no network ,this phone is unlocked ,now i am looking solution for this issue
also in my hand i have another iphone 4s ,inside have icloud id ,but dont know password ,this one also no service issue ,any good solution have without not know password i can remove old icloud id from this 4s ?
looking forwad quick reply from experter
Old 02-12-2015, 17:27   #2 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
Originally Posted by unlock & flash View Post
hello
1- iPhone 4 : it has been already hacktivated ( setup.app deleted ) , no way to gain network access again , unless you got a backup of lockdown folder before flashing or you have right iCloud ID and password .
2- iphone 4s : check in Safari settings for saved password , maybe you are lucky enough to find something usefull , also check mail settings for accounts already added , maybe the one you are looking for is already there .
__________________
Regards,
Mehdi
The Following 2 Users Say Thank You to loca|host For This Useful Post:
Old 02-15-2015, 18:24   #3 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
i am sorry to say that ,both set are iphone 4
and now inside have icloud account ,set is unlocked but no service
any way to repair network ?
Old 02-15-2015, 20:34   #4 (permalink)
DreamsUnlock's Avatar
Member: 2017165
Thanks Meter: 295
Restore & Active Both And Check Both Are Will Active Via iCloud Bypass Methood
Old 02-15-2015, 22:04   #5 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
Don't try to put him on wrong way.. Do not restore both phones or you will stuck with i cloud activation.. some how you can bypass it but in the end it will be only an ipod means no network..
Old 02-16-2015, 13:25   #6 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
phone is now as a ipod
after bypas network issue will be solved or not i dont know clearly
Old 02-16-2015, 16:09   #7 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
Do you think you are the first with this question??? Use search!
Old 02-23-2015, 19:01   #8 (permalink)
Member: 2351695
hi bro i just do icloude bypass to my iphone 4 and now there is no service problem how can i fix it plz help me.
Old 02-23-2015, 19:17   #9 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
I cloud bypass will disable gsm network..
Old 02-23-2015, 19:18   #10 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
You can't fix until.. any dev release a solution..
Old 02-24-2015, 12:08   #11 (permalink)
Member: 2351992
so cant be done,right?
Old 03-07-2015, 22:50   #12 (permalink)
Member: 1363521
hi please can sameone help me with this problem i have an iphone 4 its go off by it self and frezee when you inset the sim card even if you take out the sim card the network bar is steel there anytime i try make call i can not end the call
Old 03-09-2015, 06:29   #13 (permalink)
Member: 203335
Thanks Meter: 2
they have a solution they just wout release it i think .they make to much to release it that is my opinion ps never restore any iphone before checking to see if it is icloud lock even if you take it out of phone it might still be there always check with apple web sight it is free and it will save you lots of head ake then restore i had a iphone that had 2 icloud locks and mine and someone else i took mine out restored it then it was icloud lock with someone else i called apple they told me that there was 2 icloud locks mine and someone else i should of checked there web sight first before restoring lesson leared if it is icloud and it is a 4 you can save the actavation ticket and you will be fine to restore it good luck that is apple for you lots of security features some good some bad
Old 09-26-2015, 20:13   #14 (permalink)
Member: 1774161
hello friends,,,
i have iphone 4s having passward and icloud idi on . is there any solutions for , plz reply
Old 09-27-2015, 18:25   #15 (permalink)
Member: 1418734
Sonork: umais rasheed
can anyone tell me how to bypass icloud iphone 4s for using like an ipod...
Page generated in 0.23319 seconds with 8 queries
