10-26-2012, 10:57 | #8 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Philippines
Member: 1325931 Status: Offline Sonork: 100.1606274 Thanks Meter: 38 | |
10-26-2012, 11:44 | #11 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Bulgaria
Member: 1829069 Status: Offline Thanks Meter: 54 | You can update without any problems to 6.0, but not to 5.1.1 anymore. If you haven`t saved the SHSH before, then it is gone. This phone can not have 5.1.1, but 6.0 at the moment. |
10-28-2012, 07:49 | #12 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: kottawa,sri lanka
Member: 1095235 Status: Offline Thanks Meter: 36 | Quote:
no1- update ios6 no need unlock, do jailbreak tethered ok (n no2- solution >>>>> Step One Create a folder on your desktop called Pwnage Download the latest version of RedSn0w from here and place it in the Pwnage folder. Likewise, download the firmware you would like to restore to and the firmware you are current on from here and place it/them in the Pwnage folder. Extract the RedSn0w zip file to the Pwnage folder. Step Two Right click or control-click the redsn0w application from the redsn0w folder we extracted earlier and choose Run as administrator from the popup menu that appears. Step Three Click Extras from the main menu. Step Four Click Even More from the Extras menu. Step Five Click Restore from the Even More menu. Step Six Click IPSW from the Restore menu, choose the IPSW you would like to restore to from the window that appears, and click Open. Step Seven Redsn0w will ask you if you would like to prevent the baseband from being updated. Click Yes. Step Eight Redsn0w will inform you that Pwned DFU mode is needed to restore. Click the OK button. Step Nine Connect your device, turn it off, and then click the Next button Step Ten RedSn0w will now guide you through the steps to get into DFU mode. You can find more help with DFU mode here. Hold down both the Home button and the Power button for 10 seconds. Release the Power button and continue holding the Home button until RedSn0w detects the device. Step Eleven Your iPhone will now be exploited with limera1n. Step Twelve RedSn0w will check Cydia to see if you have the correct blobs saved. If RedSn0w is unable to find your blobs automatically you can try to click the Remote button to try again or you can click the Local button to search for blobs on your computer. Step Thir**** RedSn0w will now prepare a system restore image. Step Four**** Your device will then be restored to the new firmware. Step Fif**** You'll be informed when your restore has completed successfully. no3- jailbreak and install ipadbb... unlock ultrasnOw my 5 iphone succs.... | |
