12-08-2011, 04:06 | #1 (permalink) |
Junior Member Join Date: Dec 2011
Member: 1702393 Status: Offline Thanks Meter: 1 | Bought 3gs used on 5.0.1....need tto unlock and jailbreak...help? He had previously loaded 5.0.1 as thats what came on it. He says he saved blobs but I don't have them and hope I dont need them. I use Tmobile so i need to unlock and jailbreak. I prefer to stayt on ios 5.0.1 unless theres a major reason not to. Version: 5.0.1 (9A405) Model: MC135LL serial: xx001PSxxxx imei startts with 01 216..... firmware: 05.16.05 I assume its new bootrom but i dunno how to check and not sure what the boot rom is. I need to get unlocked for tmobile and need to go to ipad baseband 6.15 to unlock I think. Can I do the 6.15 baseband update directly from 5.0.1? Can I somehow install cydia and jailbreak? I used redsnow on my old 3g.....is there a redsnow I can use right from my 5.0.1 rtto do the baseband update/unlock/jailbreak? Must I do those in a certain order? Please help as there is too much info out there. Im confused...... |
The Following User Says Thank You to Rhizzlebop For This Useful Post: |
12-08-2011, 04:16 | #3 (permalink) |
Freak Poster Join Date: Apr 2008 Location: philippines
Member: 743134 Status: Offline Sonork: 100.1661221 Thanks Meter: 34 | https://rapidshare.com/files/4244145...ne_Checker.exe <--download this type your serial number there... check if your serial number is safe to upgrade bb |
12-08-2011, 16:10 | #4 (permalink) |
Member: 1702393 Status: Offline Thanks Meter: 1 | I downloaded the file and checked. As I thought, mine was week 01 of 2010 so its OK to update the baseband. With that said, what do I need to use to update the baseband first? Should that be done first? I'd like to just stay on IOS 5.0.1 if thats ok. I understand that I'll have a tethered unlock or is it tethered jailbreak, but since I so rarely turn my phone off that doesn't seem like such a bad thing. Can I use a version of redsnow to do the baseband? Can I stay on IOS 5.0.1? Thanks |
12-08-2011, 19:32 | #5 (permalink) |
Member: 1702393 Status: Offline Thanks Meter: 1 | Ok, If I'm reading correctly in other threads I can keep 5.0.1 I need to either download redsnow 9.9b6, or maybe snowbreeze 2.8b10?? (Which do i need and whats the difference?) Then I download the Ipad 6.15 baseband and run one of the two programs above.... I also apparently need to download an IPSW file? It reads like I need to get 5.0?? Even though I'm currently on 5.0.1???? That seems odd. Then I run the redsnow or snowbreeze, show it the IPSW file, and then go into the baseband update mode? and let it flash it?? NOTE: The page about snowbreeze 2.8b10 reads like it only works for 5.0 beta. Does it work for 5.0.1 like I have? |
12-09-2011, 13:54 | #7 (permalink) |
Member: 1702393 Status: Offline Thanks Meter: 1 | Ok, I read that link. thank you. It was somewhat helpful. Questions: 1. It says if you need to unlock then do not go to 5.0.1 I am already on 5.0.1 and I thought if I update my baseband I CAN unlock with 5.0.1. Is that correct or no? 2. That link doesn't clarify the baseband update. Do I do that before I jailbreak or after? 2 B. Can I update the baseband while it stays on 5.0.1 like it is now? 3. What is definition of jailbreak? What is definition of unlock. Which comes first? Thank you |
12-09-2011, 16:07 | #8 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Lebanon-Beirut Age: 43
Member: 180903 Status: Offline Sonork: 100.1637253 Thanks Meter: 70 | Quote:
12-09-2011, 17:08 | #9 (permalink) |
Member: 1702393 Status: Offline Thanks Meter: 1 | I'm not sure how this helps, but that link on rapidshare worked to get the checker file. I need to know if I can use redsnow or snow breeze (What version) to update m baseband while I'm on 5.0.1 and THEN unlock it on 5.0.1?? I know I have to boot tethered, but that doesn't seem like an issue IF thats the ONLY issue. There is also the semitethered add on that could be helpful. Thanks anyone....please!! |
12-12-2011, 16:31 | #13 (permalink) |
Member: 1702393 Status: Offline Thanks Meter: 1 | Thats interesting because this link Unlock iPhone 4 3GS 5.0.1 With Ultrasn0w says I can unlock 5.0.1 and talks about how to jailbreak the 5.0.1 before following the guide in that link. The only thing it does not say is whether I can update my baseband while in 5.0.1 Is THAT a problem? Why do you say 5.0.1 can't be unlocked when the info there says yes? I have a 3GS remember. |
12-12-2011, 21:17 | #14 (permalink) | |
Member: 759190 Status: Offline Thanks Meter: 4 | Quote:
yes you can..but only with this supported basebands: 01.59.00 04.26.08 05.11.07 05.12.01 05.13.04 06.15.00 yours:05.16.05... so i would check .shsh.. so you can downgrade to 4.3.3 then make an untethered jailbreak and update to 6.15.00 baseband... now you will have an unlock and untethered jailbreak 3GS | |
12-13-2011, 00:22 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Ok I am also interested to know if this is really possible. A customer brought in a 3GS updated to IOS 5.0.1 I am also assumeing that the BaseBand is aso updated (the phone is not activated). Can the baseband be still downgraded to for unlocking and jailbreak for IOS 5.0.1? Thanks |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
