eror 3194 when restore iphone 4 i try to restore in both recovery and dfu mode but no luck itunes version is latest and host file is ok but this eror :rolleyes: plz tell me solution for this how fix eror 3194 thnx in advance |
-------------------------------------------------------------------- # Copyright (c) 1993-1999 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP ad******* to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host 127.0.0.1 localhost Br, Mihut |
which iphone you are restoring and which firmware ver and itunes ver |
its your firmware version problam use latest itunes latest firmwre reset host file |
finally my problem is solve i change host file restart pc change cable and restore with last version all ok |
Try ReiBoot to enter and exit recovery mode Have you tried the freeware called ReiBoot? It is a perfect tool used to put iPhone, iPad or iPod into/out of recovery mode with one click. You can get it from google or directly download it from authorized download site CNET. |
