Old 03-25-2016, 11:28   #1 (permalink)
IbnHaneef's Avatar
Member: 2107461
Sonork: 100.1670035
Thanks Meter: 18
Arrow Remove iCloud by IMEI/Serial Repair on iPhone 4
Apple Iphone 4 is one most modifiable device , it have bootrom exploit to jailbreak we can get access into boot files for bypass icloud and many hacks are possible. But we can hack almost everything, not all you can not donwgrade baseband and you can not activated iphone 4 if not have connection with itunes. So if you bypass icloud you will not be able to unlock carrier and will be stuck no gsm. You work but like ipod. Many hackers did try fix carrier, but no good results. CMDA and GSM are also different to activate. This tool will let you use other method not hacking software .
changing IMEI and with that activate as new iphone 4 out of the box. If you want try be careful also can damage your idevice. this will work only for iphone 4.
this software let you repair imei on iphone 4 via dfu mode
https://www.youtube.com/watch?v=K7cS...ture=*********&fs=1" width="644" height="390">https://www.youtube.com/watch?v=K7cS...ture=*********&fs=1" />https://www.youtube.com/watch?v=K7cS...ture=*********">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=K7cS...ture=*********
Download Link
Source : how change imei on iphone 4 software - activation lock remove Tools icloud bypass
This will work only on iPhone 4 as per the source and also i have no iPhone 4 units to test
Regards,
IbnHaneef
The Following User Says Thank You to IbnHaneef For This Useful Post:
Old 04-07-2016, 16:01   #2 (permalink)
Member: 1145473
This method requires changing bb chip!
Old 04-09-2016, 15:47   #3 (permalink)
Cheater -Don't Deal with him-
Member: 2262340
we change the imei with other iphone?
Old 04-09-2016, 16:12   #4 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
you can test this method on any iphone 4
please share experience ???
Old 04-24-2016, 19:12   #5 (permalink)
Registered User
Member: 115596
Thanks Meter: 1,127
uart-usb-com
BH_US_11_Esser_Exploiting_The_iOS_Kernel_Slides - Download - 4shared
Page generated in 0.14484 seconds with 8 queries
