Old 10-03-2013, 12:41   #1 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
Lightbulb iphone 4 error 3194 with Ios 7
i always have the same error i checked my hosts file and downloaded 7.0.2
The Following User Says Thank You to G$m For This Useful Post:
Old 10-03-2013, 12:49   #2 (permalink)
Member: 1493666
Sonork: hai
Thanks Meter: 4
update it via itunes in dfu mode by connect your iphone when you hold on/off button and home button release on/off button after 9 second keep press home button untill itune recoganise after that press shift button and click restore selecy tour firmware its done
Old 10-03-2013, 13:37   #3 (permalink)
G$m
G$m's Avatar
Member: 995280
Sonork: 100.1582835
Thanks Meter: 91
not working
Old 10-03-2013, 13:48   #4 (permalink)
eng imran's Avatar
Member: 1640158
Sonork: 100.1615555
Thanks Meter: 138
yes i also facing this problem many time have anyone idea abot fix this ??
Old 10-03-2013, 14:02   #5 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
1) change ISP
2) download flash file of latest fimware version again (mb your file is corrupt)
3) check hosts
That's all.
Old 10-03-2013, 14:28   #6 (permalink)
eng imran's Avatar
Member: 1640158
Sonork: 100.1615555
Thanks Meter: 138
Question
Originally Posted by ribbentrop View Post
1) change ISP
3) check hosts
That's all.
some phone giving eror like this mostly same file restore fine.....
Old 10-04-2013, 20:06   #7 (permalink)
Member: 622715
Thanks Meter: 82
For the fourth phone is the same problem. I tried different versions of itunes, changed the host file. No result.
Old 10-04-2013, 20:09   #8 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 167
i dont knw this gonna work or nt just update with 6.1.3 then try to update again with 7.02 try then post result....
Old 10-04-2013, 20:12   #9 (permalink)
@matrix@'s Avatar
Member: 362515
Sonork: 100.1590585
Thanks Meter: 160
Originally Posted by tronuka37693769 View Post
same problem. This is the third phone is the same problem. I tried different versions of itunes, changed the host file. No result.
turn off ur antivirus and firewall.then replace host file with here i attached one.then restart pc and restore. post replay here
The Following User Says Thank You to @matrix@ For This Useful Post:
Old 10-04-2013, 21:46   #10 (permalink)
Member: 622715
Thanks Meter: 82
problem not solved.
Old 10-04-2013, 22:15   #11 (permalink)
Member: 622715
Thanks Meter: 82
the same problem. I think not only I have a problem.
http://forum.gsmhosting.com/vbb/f631...0/#post9782981
Old 10-04-2013, 22:34   #12 (permalink)
Member: 1427029
Thanks Meter: 5
First edit ur host file and use ireb then costom ur file and then restore ur file wth itune ur prblm will ok
Old 10-04-2013, 22:41   #13 (permalink)
Member: 622715
Thanks Meter: 82
no shsh. ios 7 custom?
Old 10-05-2013, 07:31   #14 (permalink)
hekmat-safi
Guest
Posts: n/a
Member:
bor we have to w8 for costum restore file
Old 10-05-2013, 07:45   #15 (permalink)
Cheater -Don't Deal with him-
Member: 436004
Sonork: 1620379
Thanks Meter: 105
same problem plz help
Page generated in 0.25097 seconds with 9 queries
