08-20-2010, 03:05 | #1 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1373808 Status: Offline Thanks Meter: 0 | How to Burn AVI/WMV/MPEG/3GP/MOV to DVD (Windows/Mac) The following guide shows how to burn popular video to your DVD Disc on Windows or Mac. With Joboshare DVD Creator and iSkysoft DVD Creator for Mac you can backup your video to your DVD Disc and share your dvd with your friend. Part 1: How to Burn AVI,WMV,3GP,MPEG,MP4,DAT,VOB,ASF,MPG to DVD on Windows. Step 1: Download Joboshare DVD Creator,install and run it. Step 2: Insert a DVD+R or DVD-R, or DVD+RW or DVD-RW disc in the DVD RW drive. Step 3: Add Video files Run the Joboshare DVD Creator and add the video files that want to convert by clicking "Add Video Files" or "Add Video Folder" option under the "File" menu. Or you can click the "Add Video Files" or "Add Video Folder" button in the main interface. After the video files have been added, it can be displayed in the list box in the main interface and you can set the relevant parameters according to your needs. You can customize the output aspect resize method by selecting the file's title and clicking the "Resize Method" combobox, and then there are three choices for you to set: Letterbox: add black stripes to fit the output aspect ratio Pan and Scan: crop frame to fit the output aspect ratio. Full Screen: stretch and compress frame to fit the output aspect ratio. Step 4: Select background music,DVD menu, and background picture. You can edit the DVD menu that you are interested in using the picture and music in your local computer. Click the "Edit" button and set the related information in the pop-up window, such as selecting the check box before "Background Music" or "Background Picture", and adding related picture or music file from your local computer etc. Step 5: Choose Destination. Click the "Destination" combobox to choose the form of the output file. You can choose to make DVD disc directly, or you can choose to save DVD folder or ISO files in your local computer for backup. Step 6: Start burning DVD. You can start to burn the video file by clicking "Start Burn" button in the main interface. Set the modes of the output file as "NTSC" or "PAL" by click the "Preferences" item under the "Tools" Menu before burning. Note: You can also use Cucusoft Mpeg/Mov/RMVB/DivX/AVI to DVD/VCD/SVCD Converter Pro-An professional DVD Burner software to burn your mpeg/mov/rmvb/divx/avi to DVD/VCD/SVCD. Part 2: How to Burn AVI, MOV, 3GP, WMV, M4V, TS, TP, TRP, M2TS, FLV, ASF, MOD, etc. to DVD on Mac. Step 1: Download iSkysoft DVD Creator for Mac,install and run it. Step 2: Add Video Files Click "Create a New DVD" to enter the files-add interface. Drag and drop the video directly into the program or click the "+" button to add videos As this picture shows, the added videos will be listed on the right of the main interface with its name and play time. You can double click any videos to preview in the right Preview Pane. You can also adjust the preview order by clicking the Up and Down arrows and delete the selected file with the "-"sign. Step 3: Edit Video Files Select any one of the video in the right list, and click "Edit" sign to crop, trim, or adjust the effects of your videos before burning videos to DVD. Adding watermarks for your videos is also allowed by this DVD Creator. Step 4: Edit DVD Menu With built-in dynamic and static templates resources, iSkysoft DVD Creator allows you create distinctive menus for your DVD. Step 5: Previewing the Project After finishing all the editing, you can click the Preview button on the main interface to preview your DVD project. Step 6: Burning Video Files Before burning your DVD, you can select your DVD type and the output quality at the bottom of the main interface. When you choose different formats or qualities the recoding time of the DVD is different. The table below shows the recoding time in different situations. iSkysoft DVD Creator provides four options to burn videos, that means you can burn videos to DVD disc, burn videos to DVD Folder, burn videos to ISO file, and burn video files to .dvdmedia. What’s more important, this DVD Creator allows you to save project file, which can be imported again for further editing or burning if you do not want to burn the edited videos immediately. After you finish all necessary settings, click the Start button to start creating your DVD. Now, you can just wait until the program finishes converting or burning your DVD. DVD Copy/Clone Tools: 1: DVD Copy---Copy your DVD files from One DVD Disc to another Disc professionally. 2: DVD Copy for Mac---Copy D9 and D5 DVD movies directly to DVD disc or save as DVD folder on your computer. |
04-28-2012, 02:29 | #3 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1682178 Status: Offline Thanks Meter: 2 | YouTube - How to record online music on Mac OS X? Do you want to enjoy your favorite songs or radio programs anytime on the go? Are you tired of purchasing online music again and again? Just have a try on AllMyMusic for Mac which is specially designed for Mac users to record any online music and radio programs with original quality at ease. Moreover, the recording files can be saved as MP3 or M4A format to compatible with your portable devices. This video is going to show you three steps to record YouTube music on Mac easily. Follow it and you can record your favorite audios from any websites like YouTube, MySpace, Pandora, Napster, etc. as you like. Video: |
04-28-2012, 02:30 | #4 (permalink) |
Member: 1682178 Status: Offline Thanks Meter: 2 | YouTube - How to remove password and restrictions from encrypted PDFs on Mac? PDF user password refuses unauthorized accessing of the file, while the owner password restricts copying and printing operations. This video is going to show Mac users an easy way to remove PDF passwords in seconds so that the files can be viewed, printed and copied without limitations. Video: PDF Password Remover for Mac is a small yet powerful PDF decryption tool on Mac OS X. It enables Mac users to remove copying and printing restrictions from encrypted PDF files. It works fast and supports batch decryption, which can help users quickly recover PDF documents when losing copying and printing PDF passwords. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
