12-12-2012, 00:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | itunes to iphone4 error 0xE8000012,or can I fetch shsh manually ? -I don't have 5.1.1 shsh blobs,I used redsn0w to fetch them but no result;I get success message but when I grab them using latest tinyumbrella only 6.0.1 appears -I can explore filesystem via ssh ramdisk method, if some files need to be edited. -Can I extract shsh blobs from phone manually ? like I said I can access to filesystem -latest redsn0w didn't work,iFaith doesn't support 5.1.1 your help is much appreciated |
12-12-2012, 03:18 | #2 (permalink) | |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Delete Quote:
The Following User Says Thank You to Gecko_UK For This Useful Post: |
12-12-2012, 21:50 | #5 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Today I get iphone 4 has 5.1.1,the owner screwed cydia,it doesn't work I rejailbreaked it using last redsn0w without result any solution ? Again if there is a way to correctly fetch shsh from device will be good,cause redsn0w doesn't thank you |
12-12-2012, 23:19 | #6 (permalink) | ||
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
but to fix cydia problem without restore Install this bundle with redsn0w, connect to wifi, SSH in and run following command Quote:
12-13-2012, 00:25 | #7 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | I can't find the words to thank you,but thank you very much I am interested to manually fetch shsh but I really didn't understand that COMPILE part,I need some step by step guide or maybe some wiki to learn more about it I don't want to wast your time,but when you're free plz provide me a link... by the way the phone has no shsh saved on cydia thank you again |
12-13-2012, 00:54 | #8 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | One last question,I use programmable silver card, to write desired IMSI for iphone activation purpose (using SIM-EMU) lately iphones upgraded to ios 6.x say insert sim, is there a special imsi or... to activate them ? |
12-16-2012, 14:29 | #10 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | I tryed the ssh bundle but didn't work,redsn0w installed the bundle succesfully but phone can't connect via ssh client,it says openssh not installed I realised that deb file is still in Cydia/autoinstall folder which means it wasn't installed ! Is there a way to install openssh in this case ? |
