Old 04-10-2013, 14:57   #1 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
How to Fix iPhone 4 ios 6.1.3 Restore Error -1
Then After Recover Mode Only
How to Fix This Problem
The Following User Says Thank You to FORUM-FON For This Useful Post:
Old 04-10-2013, 16:10   #2 (permalink)
Member: 1893275
Sonork: qtr_galaxy
nothing solution yet...
Old 04-10-2013, 16:22   #3 (permalink)
Member: 573569
Thanks Meter: 6
easy to fix open redsn0w exsras select ipsw ios 6.0 ok select recovry fix after this your iphone work easy
Old 04-10-2013, 17:15   #4 (permalink)
mhassanrazabj's Avatar
Member: 485816
Sonork: 100.1623308
Thanks Meter: 18
Error -1
Error occurs when one uses the "last
ditch" method for preventing
baseband updates on the iPhone 4.
The baseband does not get updated
using this method. Use FixRecovery to
kick it out of recovery mode.
Old 04-10-2013, 17:31   #5 (permalink)
Member: 932932
Sonork: bd
Thanks Meter: 40
u Chang battery 100% im success
The Following User Says Thank You to jubaer For This Useful Post:
Old 04-11-2013, 07:22   #6 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
I Try This Steps After Phone is Ok
But Phone is Activation Problem ( i Think Country Lock )
Any Way Thank you So Much
Old 04-11-2013, 07:28   #7 (permalink)
Registered User
Member: 1115410
Sonork: 100.1608126
Thanks Meter: 27
Have you tried by putting fone in dfu mode then restore..
I do many handsets successfully brother, never face din problem on ios 6.1.3..
Alway,s do restore in dfu mode.
If still facing any problem conTAct me on sonork.
Old 04-11-2013, 08:15   #8 (permalink)
GSM.solve's Avatar
Member: 1611524
Sonork: 100.1637126
Thanks Meter: 385
just change pc usb port and use orignal cable.
The Following User Says Thank You to GSM.solve For This Useful Post:
Old 04-11-2013, 10:31   #9 (permalink)
PIRATOSS's Avatar
Member: 91917
Thanks Meter: 46
this s hardw change batry if not workin probleme in board
Old 04-11-2013, 11:01   #10 (permalink)
Member: 1847840
Thanks Meter: 9
you can test restore by macbook Bro.
Old 04-11-2013, 11:25   #11 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
But After Activation Problem - Show " Connected to iTunes "
iTunes Screen Short Here :
Phone Screen Short After Select Language & Country
tinyumbrella Screen Short :
Sim Trey IMEI: 012654005764907
Part Description: iPhone 4 16GB Black
Serial Number: 7910921CA4S
Activated: Yes
Telephone Technical Support: Expired
Repairs & Service Coverage: Expired
Contract: Expired
Next Tether Activation Policy Description: Unlock.
SIM Lock: Unlocked
How to Solve This Problem &
How to Check Correct IMEI on Phone @ This Condition
Old 04-11-2013, 11:27   #12 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
if without sim its in searching it could be base band problem
Old 04-11-2013, 11:37   #13 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 63
Ya , Without Sim Full Time " searching "
Old 04-11-2013, 11:48   #14 (permalink)
Member: 1313079
Thanks Meter: 9
banseband problem, i have 1 3gs same problem, restored using latest redsnow, i saw my wifi and bluetooth gray colored, restart repeatedly, your serial number is not safe to upgrade to ipad baseband to unlock...
Old 04-11-2013, 11:52   #15 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Yesterday same problem Solved, Iphone 4 searching,
1) if have Cidia, Uninstal it
2) use redsnow and deactivate it
3) insert U Pais Sim Card and Restore it,
4) If not Restore or get Error1, (change Battry for Error 1, 100% Hw solved), in other case u have need Activation of this Iphone, i'v read Expired,
5) start whith Deactive Cidia, if have, when restore, if Serial and Imei is Errated 99% is Activaction problem,
Allumts
Page generated in 0.19923 seconds with 9 queries
