How to fix error 1618 Hello, it is a 3gs 32 gb with error 1618, i would want to restore it to original Ios, |
http://forum.gsmhosting.com/vbb/6383841-post69.html |
I have tried it but the same problem |
Error 1618 i have also same problem on iphone 3gs 16gb error 1618 the phone was working very good on 4.2.1 i tried to downgrade to 4.1 without shsh using ireb after downgrade always stuck on DFU then i upgrade again to 4.2.1 i got error 1618 then i try 4.3.1 same error 1618 4.3.2 same error 1618 i tried every thing no sucsess i think the nand chip corrupted So the only way is hardware change nand ic (i am not sure correct me if iam wrong) |
if you have install tiny umbrella in your pc v4.30 and higher. just open tiny umbrella and go to advance and untick set to cydia on exit. then close it. then open latest itunes and restore your phone, it works for me error 1618 |
Friend this solution 100% ok , i try 3 pc already How to Fix Error Code : Mac OS X: Step 1. On your Mac, go to your “Applications” folder. Step 2. Now navigate to the “Utilities” folder. Step 3. Launch "Terminal". Step 4. Type "sudo nano /etc/hosts" (without quotes) and hit return. Step 5. Enter your password Step 6. Use the down arrow key to find the “gs.apple.com” entries. Once the cursor is in front, make sure you comment out the line(s) by entering “#” in front of the text. Step 7. Save the file by pressing CONTROL+O. Step 8. Exit the nano editor by pressing CONTROL+X. Step 9. Restore your iDevice. Windows: Step 1. Start –> Programs –> Accessories Step 2. Run Notepad or WordPad Step 3. Click “Open..” from File menu. Step 4. Browse to Windows/System32/drivers/etc Step 5. In "files of type:" select all documents Step 6. Open "hosts" Step 7. Delete all line that has "gs.apple.com" or something like that Step 8. Hit Save |
tried all solution set host to cydia on exit and gs.apple on host no sucesses (every day i restore almost 10 iphones on my pc without any problem so please don't say change pc. change usb port, host edit thanks for replay |
Some users reported its battery problem. & i get success with this |
Try to resolve all means, but the same problem IPhone update other phones normally no problem Problem in the phone |
Change battery : but the same problem format pc and instal wen windows et iTunes : but the same problem Change pc : but the same problem |
aloooo hlep ............................................ |
put it in DFU mode with 4.1 original using redsn0w 0.9.6b5 then restore with 4.1 custom. done! |
1618 battery problem solution:-- tested by me 1. Disassemble iphone 2. Restore without battery 3. Eerror 1618 4. Charge battery 5. Restore firmware u wants |
