08-16-2011, 11:57 | #1 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Albania -Durres
Member: 154346 Status: Offline Thanks Meter: 37 | iphone 3gs v4.0.2 cydia problem i used limera1n but cydia not open and is white icon .any solution please thanks.klodi |
08-16-2011, 12:01 | #2 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | use Redsn0w 0.9.5b5-5 and select 4.0 ios and jailbreak your iphone. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
08-17-2011, 18:23 | #5 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Lebanon Age: 36
Member: 1424719 Status: Offline Sonork: 100.1619833 Thanks Meter: 2,563 | Do the following steps: Step 1: Open sn0wbreeze and select 4.0.2 firmware.Sn0wbreeze will verify the firmware file. Once the firmware file is verified, it will you inform you that the IPSW is verified and also the iPhone model. You will be able to click on the blue button to proceed. For iPhone 3GS users, it will request you to select whether your iPhone 3GS comes with the old or new bootrom. If you don't know, click on the Detect it for me button. You need to connect your iPhone and follow the on-screen instructions. Step 2: After selecting the bootrom, you will be prompted with three options: Baseband Preservation Mode Simple Mode Expert Mode Select Expert Mode and then click on the blue arrow. Step 3: Select General and then click on the blue arrow. Step 4: Here you will get an option to select various options such as: Enable battery percentage Enable Gestures Menu - this is pre-selected and for multitouch gestures that is only available to developers currently) Activate the Phone (Hactivate) - select this option if you don't use an official carrier SIM After selecting appropriate options, click on the blue arrow. Step 5: In the next screen, you will get an option to download apps from your favorite repos, you can skip this step and click on the blue arrow button. Step 6: Now click on Build IPSW and click on the blue arrow button. Step 7: Sn0wbreeze will now start creating the custom firmware file, which takes 5 to 6 minutes. Step 8: Once the custome is done! follow the screen for pwnd dfu and restore.. Br, Axecom |
08-20-2011, 11:59 | #6 (permalink) |
Member: 154346 Status: Offline Thanks Meter: 37 | i have tryed with limera1n but cydia is white icon and cant open .i have used snowbreeze but is not possible to restore with itunes. any other solution.thanks |
