10-31-2010, 21:12 | #181 (permalink) | |
Freak Poster Join Date: Mar 2004
Member: 60474 Status: Offline Thanks Meter: 658 | Quote:
10-31-2010, 21:40 | #182 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1431491 Status: Offline Thanks Meter: 0 | no it just wouldnt do the update, i tried 30 seconds, 33 seconds, 35 seconds etc etc etc in the end i tried to revert back to 3.2.1 using shsh blobs it froze at 99% of the restore progress bar, in the end i applied the 4.1 firmware, and then jailbroke it, no matter what i did following these instructions and/or videos i couldnt get it to work it always came up in recovery mode (even after kicking out of recovery mode using tiny or ire or irecovery command line) |
10-31-2010, 21:45 | #183 (permalink) | |
just a bad luck. you know i have done 7 iphones.using this way.... | |
11-01-2010, 14:43 | #186 (permalink) | |
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
11-01-2010, 15:12 | #187 (permalink) |
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | By the way the newest redsn0w 0.9.6B2 is out which supports loading custom IPSW from DFU mode, which means you can upgrade a handset that has been JB'ed with Limera1n or Greenpois0n to custom 4.1 firmware and keep an unlock, this is the preferred method, all users should first try this method before the 'cable trick' |
11-01-2010, 21:40 | #188 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: INNER SIDE OF MOBILE PHONES
Member: 369802 Status: Offline Thanks Meter: 82 | Quote:
11-01-2010, 22:27 | #189 (permalink) | ||
No Life Poster Join Date: Apr 2002
Member: 10964 Status: Offline Thanks Meter: 285 | Quote:
it will stop itunes before updating baseband with no need for other 'gonzales' tricks Quote:
once devteam put out pwnage for mac and with it 'special dfu mode' (in this case: loading custom firmware on new bootrom 3gs, no baseband update) there was no need for the ' cable trick' the method i was using to get the 'special dfu mode' was: 1. from recovery mode - irecovery.exe -p custom_activated_4.1.ipsw 2. from dfu mode run greenpoison 3. finish irecovery - after this you will have dfu mode that will allow custom firmwares 4. load custom_activated_4.1.ipsw with itunes even after this people still prefer 'cable trick' Last edited by sorinm; 11-01-2010 at 22:34. Reason: merging posts | ||
The Following User Says Thank You to sorinm For This Useful Post: |
11-02-2010, 01:00 | #190 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 41
Member: 162611 Status: Offline Thanks Meter: 315 | Please all membres this forum for this problème this the solution : For iphone4 you need Umberlla and start tss server and restore your iPhone withe original firmware 4.1, in restore iTunes stop opération in 70% and you Will get iPhone in 4.1 withe old basband (this solution work in Mac/Windows ) And for iphone3GS you need Powbanagetool New version and created custom firmware and restore it withe iTunes And thank you for all |
11-09-2010, 20:08 | #193 (permalink) |
No Life Poster Join Date: Sep 2004 Age: 47
Member: 84128 Status: Offline Thanks Meter: 110 | now u can use this trick to update 3gs with 4.1 cutom firmware very easy no need to pull out cable http://forum.gsmhosting.com/vbb/f456...linux-1127309/ if u cant understand u can contact me |
11-12-2010, 18:11 | #194 (permalink) |
Junior Member Join Date: Nov 2008
Member: 909744 Status: Offline Sonork: rock Thanks Meter: 0 | life is what you make it so you can unlock all S L3 phone????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? * ?????????????????????????????????????????????????? ???????????????????????? |
11-19-2010, 06:52 | #195 (permalink) | |
Junior Member Join Date: Nov 2010
Member: 1446381 Status: Offline Thanks Meter: 0 | Quote:
I have a 3gs firmware 3.0 jailbroken and unlocked. Will this method work, that is, if I follow this instruction, at the end do I get a new firmware without the need to jailbreak and unlock again? I also have 4g with 4.1 already installed by itune. I'm guessing the baseband is updated. Can I still jailbreak and unlock? or it's a dead-end? I found the instructions at iclarified.com but they forewarn that 4g needs to upgrade to 4.1 using TU first. Well I'm already on 4.1 and found out about all of this jailbreak and unlock Thanks, Newb Last edited by bgnecnakh; 11-19-2010 at 07:01. | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
