Old 06-25-2011, 10:58   #1 (permalink)
royal_electronics's Avatar
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow iphone4 error 3194 show in restor & updation
when i try to restor & update iphone4 its show error 3194. plz help how i fix it .thanxx
The Following User Says Thank You to royal_electronics For This Useful Post:
Old 06-25-2011, 11:03   #2 (permalink)
Member: 528712
Thanks Meter: 11
you need edited host first, then restore...
The Following User Says Thank You to mendones_j For This Useful Post:
Old 06-25-2011, 11:16   #3 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Close iTunes.
Locate the Hots file:
Windows:
Go to C:\Windows\System32\drivers\etc\ and locate hosts file.
Open and edit the hosts file in Notepad.
Note: Win 7 and Vista users MUST run Notepad with admin privileges. Right click on Notepad app and select Run as Administrator.
Mac OS X:
Go to \etc\ directory and locate hosts file. Copy it on your desktop
Open the hosts file in TextEdit.
Add the following lines to the very bottom of the hosts file:
74.208.105.171 gs.apple.com
remove any other line that contains gs.apple.com
Put your iDevice into DFU Mode and Try restoring it via iTunes.
That’s it! You should now be able to successfully restore
Old 06-25-2011, 11:26   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
after EDIT host file ,restart pc
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 06-25-2011, 12:20   #5 (permalink)
Redknight07's Avatar
Member: 1478277
Thanks Meter: 41
First we need which version u restore to ur iphone......
Apple just accept latest firmware restore if u don't have old firmware shsh to restore earlier Firmware........
Redknight07
Old 06-25-2011, 13:29   #6 (permalink)
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow
this is error show in restor & updation
Uploaded with ImageShack.us
i try this version for restor : >
iPhone3,1_4.1_8B117_Restore
Old 06-25-2011, 13:51   #7 (permalink)
Crazy Poster
Member: 285845
Thanks Meter: 2
restor with 4.3.3, all will be ok (no need to edit host file)
post result.
Old 06-25-2011, 15:19   #8 (permalink)
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow
post result.
helloo brother, i try to restor with 4.3.3 but not sucess . show this error.plz solution urgent.
Old 06-25-2011, 16:45   #9 (permalink)
Member: 1427645
Sonork: sohail----
Thanks Meter: 27
mostly this error comes its mean u need to up date new version online update....
if its same ..u change host file. copy and past
# Copyright (c) 1993-1999 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP ad******* to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
cont.iphone to pc.in recovery mode
used tiny umbrella..mobile show recover mood then start tss server
open i tune restore after any error..used..redsn0w_win_0.9.8b1
best of luck thnx
Old 06-25-2011, 20:37   #10 (permalink)
Member: 508032
in tinyumbrela go to advance and uncheck set host to cydia on exit.
Old 06-26-2011, 14:15   #11 (permalink)
Crazy Poster
Member: 285845
Thanks Meter: 2
http://forum.gsmhosting.com/vbb/f456...blems-1280010/
check here
Old 06-26-2011, 18:33   #12 (permalink)
Member: 1575479
Thanks Meter: 29
Hello, bro you have another way.
Fix iTunes Error 3194 When Restoring / Updating To Stock or Custom 4.3.3 Firmware
see bro link here Fix iTunes Error 3194 When Restoring / Updating To Stock or Custom 4.3.3 Firmware | Redmond Pie
http://www.redmondpie.com/wp-content...2011/05/TU.png
It is usefully bro...
Thanks bro
kingofbird
Old 06-27-2011, 06:06   #13 (permalink)
Member: 397892
Sonork: 100.1609899
Thanks Meter: 190
Arrow
thanxx every body , my problem is solved after update itune latest version & restart computer.thanxx again
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 8 10-31-2012 20:17
Nokia 5110 & 6110 Schemics MyKy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-06-1999 08:36
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-24-1999 05:45
Page generated in 0.18388 seconds with 9 queries
