Old 11-02-2012, 06:44   #1 (permalink)
Member: 84
Sonork: 100.1616161
Thanks Meter: 2,617
How to jailbreak iOS 6.1 beta
If you’re a developer wishing to jailbreak your pre-A5 device running iOS 6.1 beta, then you’ll be happy to know that it can be easily done using the same method we used to jailbreak the iOS 6.0.1 public release.
This is, of course, a tethered jailbreak, and it only works with pre-A5 devices like the iPhone 4, or the iPhone 3GS. For the full video tutorial, check inside…
Note: iOS 6.1 beta is for developers only.
Step 1: Download RedSn0w 0.9.15b3 and iOS 6.0 from our Downloads page.
Step 2: Place your pre-A5 device into DFU mode with it connected to your computer.
Step 3: Open RedSn0w, and click Extras > Select IPSW, and select the 6.0 firmware for your device. It should successfully identify the 6.0 firmware. Click back.
Step 4: Click Jailbreak on the main page of RedSn0w, then once it’s finished loading, ensure Install Cydia is checked and click Next.
Step 5: The jailbreak process will begin, and it will take a bit to finish. Once finished, you should be at your Lock screen. Close out of RedSn0w.
Step 6: Place the device back into DFU mode, and reopen RedSn0w. Go to Extras > Select IPSW, and again point to the 6.0 firmware.
Step 7: Once it successfully identifies, click Just boot. A tethered boot will be performed, and eventually you’ll end up back on your Lock screen. Unlock the device, and you should see Cydia on the second page of your Home screen.
Congratulations, you just jailbroke iOS 6.1 beta.
As always, we recommend that you check out our dedicated RedSn0w tutorial page for more instruction regarding RedSn0w. Also, be sure to let us know what you think in the comments below.
Mobileinfo
The Following 26 Users Say Thank You to mobileinfo For This Useful Post:
Old 11-02-2012, 06:50   #2 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
nice information bro.thanks................
Old 11-02-2012, 06:53   #3 (permalink)
softwarewala's Avatar
Member: 1550394
Sonork: 100.1594422
Thanks Meter: 26
nice info keep it up
Old 11-02-2012, 07:06   #4 (permalink)
Member: 1811243
Thanks Meter: 5
i have iphone 4s 6.0 .. is it works on my phone
Old 11-02-2012, 07:39   #5 (permalink)
Member: 1331968
No ! not wrking with A5
Old 11-02-2012, 09:23   #6 (permalink)
Member: 1815277
Sonork: n04-11-005634
Thanks Meter: 5
sir i have a iphone4s 64gb. a problem network searching...and other network it use it says invalid sim.. how to unlock this..thankz...
Old 11-02-2012, 09:26   #7 (permalink)
Member: 541042
Thanks Meter: 519
No Unlock
READ First, whats Baseband Supportet for Unlock
Old 11-02-2012, 09:35   #8 (permalink)
Member: 1807151
thanks.....................................
Old 11-02-2012, 13:19   #9 (permalink)
s a dot com's Avatar
Member: 1779651
Sonork: 100.1603336
Thanks Meter: 97
thanks for info bro
and
always work hard bro
Old 11-02-2012, 16:37   #10 (permalink)
alimaher_gsm's Avatar
Member: 138904
Sonork: 100.1587834
Thanks Meter: 662
useful info.....Keep it up.....^_^
Old 11-04-2012, 08:37   #11 (permalink)
IQA_SHAHEEN's Avatar
Member: 1453428
Sonork: 100.1596919
Thanks Meter: 146
rocking update by dev team
regards
iqa_shaheen
Page generated in 0.17137 seconds with 8 queries
