11-07-2012, 23:20 | #1 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Slovenia Age: 48
Member: 15385 Status: Offline Thanks Meter: 9 | iPhone 2G, unlock and jb, popup message i have a problem and first i must tell you , that i did everzthing as is written: 1. update my iphone 2g to 3.1.3 via iTunes 2. after that i run Redsnow ver 0.9.4 3. i chose firmware 3.1.2, bootloader 3.9 and 4.6 and run it 4. everzthing made ok, but when i tur on the phone, pop up message shows on the screen 5. Message "Edit Home Screen" and Dismiss function wont work, so i can not go on useing my phone 6. if i try to call this phone, everzthing is ok, i recieve sms and call, but cant turn off this pop up message how to downgrade from 3.1.3 to 3.1.2 to unlock and jailbreak this pfhone? Or you maybe have an other solution? Problem is, if i upgrade it to the latest version 3.1.3, phone stop at the beggining as a dont have original SIM to activate it. Any halp, please. BR, Dejan |
11-08-2012, 08:22 | #3 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | Unlock 3.1.3 Dont have shsh. If i reload firmware 3.1.3 over the iTunes, phone is locked and it stuck at the beggining when it says, that I need to insert the right SIM card, and if I unlock and flash it by the manual written by this manual, phone is unlocked and I can recieve sam and cals, only popup message can not turn off and also can not go further useing my phone. Any advice? Thanks in advance. |
11-23-2012, 15:21 | #4 (permalink) |
Member: 15385 Status: Offline Thanks Meter: 9 | Solution Hello, I manage to get rid off this message Edit Home Screen. For others, that also have this kind of problems, here is what you should do. 1. Turn ON the phone, this message wil pop up 2. From other phone sned an SMS to this iphone 3. When you recieve SMS, hit replay 4. After that, turn your phone Landscape, and hit Dismiss 5. If you want, that this message will not show each time you turn on your phone, do next 6. Install Activator, Install SBSetings 7. Restart Iphone and thats it. BR, Dejan |
