Iphone 3g passcide Hope there is a solution, I have an iphone which I put a passcode on but I do not remember it. I just wanted to know what is the default passcode of an iphone 3g? is it threre anyway to reset the passcode? does the passcode resets when you restore the phone? thank you |
Search the forum for "iPhone_Password_Remover" and download it Regards, |
through the restore is possible to remove the old password? ok thanks ill try that |
the restore will remove all data including your password. But if you use the password remover you will not loose any of your iphone data. |
and just so you know the passcode remover will only work if the phone is jailbroken |
Ok the phone is jaibroken thrgouh spirit and unlocked also. I triedd different methods such as iphone browswer which doesn't connect at all with the iphone,i tried to connect in restore mode but nothing. I tried some batch files given in the forum ,when I run them,they say the phone is attached and then exit, then i restart the iphone and the passcode is still there. what should I do? |
