12-16-2011, 13:03 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | Apple Mobile Device service consuming 100% CPU in XP Any advice |
12-17-2011, 07:04 | #6 (permalink) | |||
No Life Poster Join Date: Feb 2009
Member: 961957 Status: Offline Sonork: Jabber: [email protected] Thanks Meter: 641 | Quote:
iTunes 10.5 for Windows: May see performance issues http://brianmorristech.com/?p=762 They give you a long set of instructions, But this simple fix posted around is working for most people, only need few commands (tested by myself): 1) open command prompt in admin mode 2) type the following command Quote:
If you still notice high CPU usage then end the "APSDaemon.exe" process with task manager and check again. If that has fixed it then copy this code into notepad, save as disableAPS.reg file and double click it and reboot machine. This will prevent the deamon from running Quote:
Remove all iTunes related components (not just itunes) using control panel, re-install latest version and repeat steps. you can alternatively add an exception to apsdaemon if your security product allows it | |||
The Following 3 Users Say Thank You to Gecko_UK For This Useful Post: |
12-20-2011, 23:44 | #7 (permalink) |
Member: 21296 Status: Offline Thanks Meter: 328 | This should be the solution. I have NOD32 protected MSAFD TCP/IP, but I have had NOD since ages there, but Apple is making troubles wih these everyday iTunes updates. I will try and I think that it should also work uninstalling NOD32 software... |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
