Iphone 3gs 4.2.1 stuck in dfu mode 10000% solution Use iREB-r4 and do ireb for 3gs restore 4.1 restore firmware(no custom firmware) shift+restore in itunes after restoring you get restore mode use "recovery mode loop fixer" in iREB-r4 use simcard for activation OK |
Success! Yeah man! This will help really. FW 4.1 will fix this problem. tested on 3GS and 3G that stuck in restore. !!!!! helps also on 3G !!!!! thanks a lot ! |
do u need saved shsh for this?because i dont have saved shsh for 4.1. |
there the short cut, you need to put DFU Mode., Restore with Customized activate, then jaibreak with red snoow after that jaibreak with grean poison unlock with wi-fi or without wifi, i mean iphone foldeer, by coppy ultrasnow 1.6to the folder cydia, read very carefully you will find good solution, no need to find wi-fi and no stuck again |
i really thank u after a search of hours !!! i almost hated iphone ! thanks for sharing this !!! |
