Old 08-09-2010, 15:17   #1 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
Thumbs up Few iphone 3G , 3Gs and 4 shows different sim detected Solution here
Why ?
because jailbreak is good but not perfect
Solution :-
as jailbrake is good but not perfect so we need a little modification in some iphones after jailbreak and unlock .
To remove Different sim detected error
Most easiest way is
1. After jailbreaking, launch Cydia
2. Go to manage/sources, tap edit/add
3. type cydia.pushfix.info/ , add source
4. tap done, browse newly added source Pushfix.info
5. choose Hacktivation Patch (lockdownd), install
6. done.
few other ways are mentioned below
first of all u
pdate cydia
than press search in Cydia than search for AFC2ADD and install it
download this software ifunbox ( This will help u browse and put lockdown file in ur iphone which is attached below )
http://www.megaupload.com/?d=OLULS530
go to /private/var/root/Library/ and delete orginal lockdown folder and put attached lockdown folder
after this just restart ur iphone
if still same then use Winscp and change 0755 value of lockdown to 0644
download link of Winscp http://www.megaupload.com/?d=AUCCA0X0
If anyone needs any guidance than i am here for u
The Following 20 Users Say Thank You to bappi1 For This Useful Post:
Old 08-09-2010, 15:55   #2 (permalink)
mobile_hotman's Avatar
Member: 214340
Thanks Meter: 906
already posted by MANISH_SK 1st in this section,,any way thanx for such help
The Following User Says Thank You to mobile_hotman For This Useful Post:
Old 09-03-2010, 18:17   #3 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
If you experience this error "Diffrent SIM Detected" afte the jailbreak process, here is my solution for that
Download the files we need for this Tutorials:
iFunbox : http://www.pars-gsm.com/Downloads/ifunbox_en.zip
New Lockdown RapidShare: 1-CLICK Web hosting - Easy Filehosting
Run the Software and Sync with iPhone
Now go to /private/var/root/Library/ and delete orginal lockdown folder and put attached lockdown folder
At last reboot your iPhone Phone must be ok now.
Thanks
The Following 3 Users Say Thank You to bappi1 For This Useful Post:
Old 10-10-2010, 13:01   #4 (permalink)
Member: 104515
Thanks Meter: 77
Why ?
Solution :-
Most easiest way is
6. done.
first of all u
pdate cydia
3GS 4.1 -different-sim-detected-solution ERROR HACKKTIVATİON PACH İNSTAL ERROR
The Following User Says Thank You to leventturksoy For This Useful Post:
Old 10-10-2010, 15:27   #5 (permalink)
kushol's Avatar
Member: 293662
Sonork: 100.1622609
Thanks Meter: 317
Its Not Work 4.1
The Following User Says Thank You to kushol For This Useful Post:
Old 10-10-2010, 16:24   #6 (permalink)
Member: 458519
Thanks Meter: 2
iphone 3gs 4.0.2 fixed thanks,
all i did was delete the folder lockdown and restart.
i didnt understand the bit, put attached lockdown folder?
The Following User Says Thank You to amin12345 For This Useful Post:
Old 10-11-2010, 14:47   #7 (permalink)
msashami's Avatar
Member: 181213
Sonork: 100.1586186
Thanks Meter: 201
sorry but i dont understand "and put attached lockdown folder" where is attached lockdown folder???
WBR
The Following User Says Thank You to msashami For This Useful Post:
Old 10-11-2010, 15:26   #8 (permalink)
Member: 320205
Thanks Meter: 181
10000000000000000% ok tested ok
The Following User Says Thank You to sampat_shah For This Useful Post:
Old 10-12-2010, 11:22   #9 (permalink)
Member: 46557
Thanks Meter: 6
yes,where is attached lockdown folder???
The Following User Says Thank You to epu_lo For This Useful Post:
Old 10-13-2010, 17:52   #10 (permalink)
Member: 1255356
Sonork: 100.1607364
Thanks Meter: 129
Why ?
Solution :-
Most easiest way is
6. done.
first of all u
pdate cydia
could u explain step by step that how to change value of lockdown 0755 to 0644 thanx
Old 10-20-2010, 08:55   #11 (permalink)
Member: 183851
Sonork: 100.105150
Thanks Meter: 19
Yes its work for me also.
Old 10-20-2010, 09:30   #12 (permalink)
Chiran's Avatar
Member: 718059
Sonork: 100.1587605
Thanks Meter: 36
Good solution, thanks!!!!!!!!!!
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-13-1999 19:18
Page generated in 0.19410 seconds with 9 queries
