IPhone 3GS stuck at apple + loading like tethered after downgrade IPhone 3GS stuck at apple + loading like tethered after downgrade Anyone know how to bypass that? |
thanks for replies i am confused with so many options :) |
what version did you put in |
try to downgrade it via dfu mode use version 4.1 error 1015 kick recovery mode via recboot |
if i put 4.2.1 or 4.1 is always the same... |
that strange because i have 2 phones with the same and only appers like this after downgrade. |
use custom without baseband. use pwned dfu to restore custom. if everything go without error. check your phone started fully or still stuck on spinier . if spinier or applet logo only then you have faulty hardware parts.. nand or baseband chip etc.. if start ok use original card to active and then only jail break if everything ok.. Regards:Chevli |
i dont see where is the problem phone is working ok before downgrade... i tried all , i go to one friend and he get that working uch.... |
now what is prob recovry mode or stack on apple ? |
Listen ATM apple is signing 4.1 & 4.3.5 so the only firmwares you can restore without shsh are 4.1 & 4.3.5 If your device's have bb6.15 installed so you are not able to install any firmware always you try to restore you will gt 1015,1013 error which ends in DGU or recovery mode So the only thing can bring your devices back Put your device in recovery mode edit the host files and delete the tinyumberella host server line and then restore your devices with custome 4.1 :) If your phone's are not with bb 6.15 so you have to install 4.3.5 first then you can donwgrade with a cfw so the best option is try to restore with CFW 4.1 ;) |
