04-07-2014, 22:30 | #46 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gizah/Egypt Age: 33
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | but it doesn't work .. and according to other guides when i press launch in Gecko tool i should see AppleKeyStore:sending on my iphone screen but the only thing i see is (AppleBCMWLANCore: :handleIOKiBusyWatchingTimeout(): Error, no successful firmware download after 60000 ms!! Giving up...) you said ignore errors and just wait .. should i ignore that error too ??? also Gecko doesn't hang or freeze (Trying all 4-digits passcodes...) another question .. isn't the passcode stored in a .plist file i can look for and just edit it through the ssh ramdisk ?? |
04-08-2014, 13:19 | #48 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Neverland, Hell
Member: 337327 Status: Offline Thanks Meter: 6 | When I try to bruteforce the passcode on iphone 4 (3.1) ios 7.1 I get the redsn0w shows big OK but then comes with this: AppleKeyStore:sending (AppleBCMWLANCore: :handleIOKiBusyWatchingTimeout(): Error, no successful firmware download after 60000 ms!! Giving up...) Then I press launch on Gecko Tool, it freezes for 5 seconds and unfreezes without any passcode then. Any advice? |
The Following User Says Thank You to logica1 For This Useful Post: |
04-08-2014, 15:45 | #49 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Lithuania
Member: 1099349 Status: Offline Thanks Meter: 106 | you cant view passcode in any plist file. i think your problem is that you wait too long when a Big OK on iphone screen appears,, once you see its OK on lcd, press LAUNCH in Gecko fast.. i can make a video of what im doing, but it doesnt change anything... and this error that unsuccessful firmware download,... it should appear in between Sending rows after some minute or two after you press LAUNCH normally... we all got that error... |
The Following User Says Thank You to decco For This Useful Post: |
04-08-2014, 16:57 | #50 (permalink) |
Member: 594436 Status: Offline Sonork: 100.1657777 Thanks Meter: 952 | i'll try again and let you know if it works .. thx for the help |
The Following User Says Thank You to MiRoOo For This Useful Post: |
04-11-2014, 01:49 | #53 (permalink) |
Junior Member Join Date: Nov 2005
Member: 203335 Status: Offline Thanks Meter: 2 | will this work on iphone 4 cdma if not how can i read the passlock on verizon iphone4 dont want to restore it so it dont restore to 7.1 it is on 7 want to keep that iso so i can jailbreak it please help |
04-11-2014, 08:25 | #54 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | just read the post ! makse sure JAVA JRE AND netframework 4+ is installed to w0rk this t00ls ! |
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
04-11-2014, 17:14 | #55 (permalink) | |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | decco you have any ideo Quote:
04-11-2014, 20:50 | #56 (permalink) | |
Member: 1099349 Status: Offline Thanks Meter: 106 | Quote:
what you are talking about? i cant understand your language,,, please try to write your problem as clean as possible.. you want to change icloud password? you cant.. but you can do another trick with this if your iphone is factory unlocked and activated but passcode locked.. as i said, just try to be clear.. | |
04-11-2014, 22:21 | #57 (permalink) | |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Quote:
Sent from my GT-I8190N using Tapatalk | |
04-12-2014, 06:37 | #58 (permalink) | |
just try on other computer, maybe it will work. You can try to put mobile in lost mode via icloud. then it will ask you ti add passcode, so add it.. and check how it works.. but this sounds to easy... what is your iphone revision? and iOS ? and JAVA version ? | |
04-13-2014, 04:42 | #59 (permalink) |
Member: 203335 Status: Offline Thanks Meter: 2 | will this work with iphone4 cdma no one has ansered my question let me know if not how can i get my user lock off of my phone dont rerember screen lock code and dont want to restore phone so i dont loose my jailbreak |
04-13-2014, 10:09 | #60 (permalink) | |
"Device unsupported" If i helped you press thanks button ↓ | |
