iPhone 4 network issues Hello Members, I have received a iPhone 4 and it has not network connector how can I tap. |
Same problem please... |
I had this issue aswell and i went to a shop and they started up the phone with a computor and helped me to install everything to get it working. Go to your closest mobileshop and they can prolly help you out. Good luck with it! |
you need to full flash to solve IMEI problem chk on icloud statue.. using IMEI at any iphone info web if Find my iphone is : locked be sure that u have icloudand password connect your phone to ur computer and restore it from itunes * don't restore iOS devices if find my iphone statue is locked without having icloud id and password |
nice shearing thanks |
iDoctor reparation iphone Network problem is considered to be one of the most common problems that occur in smart phones. Normally there are three type of network issues such as low Signal, No Signal and signal keeps on dropping. Remove and reinsert SIM card can be simple solution for this. If the above method doesn’t work then restart your iPhone and you update your software properly. |
Any one done fix network after bypass? |
