Old 01-21-2012, 06:43   #1 (permalink)
Member: 430612
Thanks Meter: 301
Iphone 4 no network signal
it show operator name but when you call it show call fail even emergency number i need help
Old 01-21-2012, 06:46   #2 (permalink)
Member: 23372
Thanks Meter: 18
try to restore your aphone 4
Old 01-21-2012, 09:29   #3 (permalink)
Member: 430612
Thanks Meter: 301
i restore it but still the same.................
Old 01-21-2012, 12:57   #4 (permalink)
gooshi_shah's Avatar
Member: 614090
Sonork: 100.1583645
Thanks Meter: 66
ultrasnow patch again and try
Old 01-21-2012, 15:55   #5 (permalink)
Member: 501219
Thanks Meter: 27
I had a no signal problem after replacing the lcd
I read up about it and how to fix it was to solder two tiny pins beside the antenna
I just joined them together and I got full signal
Ill find you a screen shot if you need one
Old 01-22-2012, 07:50   #6 (permalink)
Member: 430612
Thanks Meter: 301
pleassssssssssssssssssssssssssssssssssssssssssssss sssssss
Old 01-24-2012, 14:21   #7 (permalink)
Member: 501219
Thanks Meter: 27
I can't find the pic I used bud if you look at your phone where the black wire plugs in well on the left side of that youl see two points it's not them two points your looking for look to the left of them again under the ribbon flex you will see another two points there beside a gold part looks like a gps antenna well a small bit of solder on them two and youl have full signal
Hope you can under stand what I am explaing
Let me know
Old 01-24-2012, 16:30   #8 (permalink)
Member: 1710966
Dear luyanda,
Same problem i have in my iphone 4 when you solve the your problem let me know please.
Regards,
Fazli
Old 01-25-2012, 02:00   #9 (permalink)
Member: 501219
Thanks Meter: 27
You can test my solution with a bit of tinfoyle or a screw driver before you solder just join the two contacts together
6150 Network problem, please HELP! ZF Nokia Hardware & Hardware Repair 4 07-06-2004 18:07
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
How do I remove a network provider lock? james.bond007 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-02-2000 22:59
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.19369 seconds with 9 queries
