03-07-2015, 00:10 | #3 (permalink) |
No Life Poster Join Date: Sep 2012 Location: IN JUPITER
Member: 1812784 Status: Offline Thanks Meter: 45 | this error always coming from Iphone 4 SOLD BY APPLE HONG KONG, u cannot update to ios 7.1.2 but u can downgrade successfully if u have save shsh blob i think no one have gotting solution for this apart from hardware solu, i have 5 pcs of iphone 4 all stuck on same error |
03-07-2015, 00:22 | #4 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | Check host file update itunes to latest version use good cable disable all antivirus/security/FIREWALL CHECK YOUR INTERNET CONNECTION also try on other pc. |
03-07-2015, 17:12 | #8 (permalink) |
No Life Poster Join Date: Sep 2013 Location: The Hell Age: 31
Member: 2033150 Status: Offline Thanks Meter: 624 | make sure ur host is like this remove anything else ---------------- # Copyright (c) 1993-2009 Microsoft Corp. # # This is a sample HOSTS file used by Microsoft TCP/IP for Windows. # # This file contains the mappings of IP addresses to host names. Each # entry should be kept on an individual line. The IP address should # be placed in the first column followed by the corresponding host name. # The IP address and the host name should be separated by at least one # space. # # Additionally, comments (such as these) may be inserted on individual # lines or following the machine name denoted by a '#' symbol. # # For example: # # 102.54.94.97 rhino.acme.com # source server # 38.25.63.10 x.acme.com # x client host # localhost name resolution is handled within DNS itself. # 127.0.0.1 localhost # ::1 localhost -------------------------------- |
