iphone 4g modem ver 1.59.00 i m at ver 4.2.1 as my modem firmware is 1.59.00 so can it be unlocked.if it can ,what will be the procedure |
yes this unlocked no problem open cydia inistall ulthrasn0w 1.2 |
thnxxxxxxxxxxxxxxx i will try |
Step One Open your web browser of choice and navigate to http://www.greenpois0n.com. Click the Windows link at the bottom of the screen. http://www.iclarified.com/images/tut.../41440-500.png Step Two When prompted save the download to your desktop http://www.iclarified.com/images/tut...7459/47459.png Step Three Double click the downloaded gp_win_rc5_b2.zip file then drag the greenpois0n.exe file to the desktop. Double greenpois0n.exe from the desktop to launch the application http://www.iclarified.com/images/tut.../47461-500.png http://www.iclarified.com/images/tut...7460/47460.png Step Four Power off your iPhone then click the large Prepare to Jailbreak (DFU) button http://www.iclarified.com/images/tut.../47464-500.png Step Five You will now be instructed on how to place your iPhone into DFU mode. You can get help with this here. http://www.iclarified.com/images/tut.../47465-500.png You will be asked to press and hold the sleep button for 2 seconds. |
Continue holding sleep; press and hold home for 10 seconds. http://www.iclarified.com/images/tut.../47467-500.png Release sleep button; continue holding home for 15 seconds. http://www.iclarified.com/images/tut.../47468-500.png Step Six Once your iPhone is successfully in DFU mode you may click the Jailbreak button. http://www.iclarified.com/images/tut.../47469-500.png Step Seven Greenpois0n will now jailbreak your device http://www.iclarified.com/images/tut.../47471-500.png |
Step Eight Click the Quit button once the software application has completed. http://www.iclarified.com/images/tut.../47472-500.png You'll notice some verbose mode text scrolling on your device. Step Nine After the iPhone restarts you'll notice a new Loader application on your Springboard. Press to launch it. http://www.iclarified.com/images/tut...7474/47474.png Step Ten Press to select Cydia then press the large Install Cydia button that appears. http://www.iclarified.com/images/tut...7475/47475.pnghttp://www.iclarified.com/images/tut...7476/47476.png |
thankas bor............................. |
Step Eleven Once Cydia has installed successfully you can remove Loader by pressing the Options button then the large red Remove Loader.app button. http://www.iclarified.com/images/tut...7477/47477.pnghttp://www.iclarified.com/images/tut...7478/47478.png Step Twelve Restart your iPhone then run Cydia. Let it do all the necessary updates then follow our belu http://www.iclarified.com/images/tut...7479/47479.png |
Step One Press to launch Cydia Installer from your SpringBoard. http://www.iclarified.com/images/tut...6522/16522.png Step Two Press to select the Manage tab at the bottom of the screen. http://www.iclarified.com/images/tut...6523/16523.png Step Three Press to select the large Sources button http://www.iclarified.com/images/tut...6524/16524.png Step Four If the ultrasn0w repo is not present press the Edit button at the top right of the screen. Otherwise, skip to Step Nine. http://www.iclarified.com/images/tut...6525/16525.png Step Five Press the Add button at the top left of the screen. http://www.iclarified.com/images/tut...6526/16526.png Step Six Enter ultrasn0w.com as the source url and press the Add Source button. http://www.iclarified.com/images/tut...6527/16527.png Step Seven Once the source has been added press the large Return to Cydia button. http://www.iclarified.com/images/tut...6528/16528.png Step Eight Press the Done button at the top right of the screen. http://www.iclarified.com/images/tut...6529/16529.png |
Step Nine Press to select repo666.ultrasn0w.com from the list of user entered sources. http://www.iclarified.com/images/tut...6530/16530.png Step Ten Press to select ultrasn0w from the list of packages http://www.iclarified.com/images/tut...4946/44946.png Step Eleven Press the Install button at the top right of the screen. http://www.iclarified.com/images/tut...4945/44945.png Step Twelve Press the Confirm button at the top right of the screen. http://www.iclarified.com/images/tut...4944/44944.png Step Thir**** After installation completes successfully press the large Restart Springboard button. http://www.iclarified.com/images/tut...4943/44943.png Step Four**** You should now be able to insert the SIM of your choice! http://www.iclarified.com/images/tut...6537/16537.pnghttp://www.iclarified.com/images/tut...6538/16538.png |
*********************UNLOCK IPHONE 4,3;3GS************* ultrasn0w - ultrasn0w 1.3b |
