Iphone is disabled my i phone is showing message(I PHONE IS DISABLED CONNECT TO I TUNES) how to remove password without flashing?images are important for me... please help |
whitch iphone? 3G 2G ??? version? i suppose you can not enable your iphone without flashing. |
NO solution without Restore |
cant find the virsion phone is locked.... i tried this method http://forum.gsmhosting.com/vbb/f456...itunes-722040/ but can open the software getting a error... |
no way to remove password.because when you want explore the phone the software give error...:-( the only way its restore it with ******* firmware to save basebande good luck:) Quote:
Tell me what software version is on the phone, and which model ie 3GS 4.2.1 I will post the files you need to remove iphone disabled screen without itunes restore br |
sir i have 3gs with 4.1 pl. send any sol. for removed i phone disabled without restoring it |
thanks Quote:
i had little program about that. but it was work only on 2.0 - 2.1 software versions... i can not find any program or utility for new versions... |
no other solution just restore.......... |
Here is the solution for your phone, this bundle will remove 'iPhone disabled' on 4.1 3GS without DFU restore, will take about 1- 2 minutes http://iphonerepairs.org.uk/download....org.uk.tar.gz to use this, simply put your iPhone in DFU mode, start redsn0w 0.96b6 and tick only 'Install custom bundle' then browse to the file i have uploaded above. You don't need to install Cydia or any other option. when the phone starts up again it will be enabled, It just writes 'fresh' springboard prefs with springboard devicedisabled key set to false In case you don't realise this is solution for 'iPhone disabled' NOT for removing iPhone password. for removing password on 4.x firmware you must use ramdisk and manually backup and restore, frm data protection. since password involves system keybag, no longer in keychain BR gecko |
to remove password on 4.x firmware using msft guy SSH ramdisk builder here is a very basic script to allow you SSH over USB access, (full instructions on his site), once you mount the disks you can use another script to retrieve your photos, music etc or do it manually. of course replace the ramdisk, kernelcache, ibss to iOS/device specific for your needs, you can grab the decryption keys from iPhonewiki for any firmware in order to unpack and generate the ssh ramdisk Quote:
hello Quote:
Tried it on a 3GS iphone is disabled, but didn't make any difference.:confused: |
tryed 3g nothing happn.... |
