05-01-2009, 18:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | iphone pcb repair It seems like i kinda bent the pcb where there is a small tab that has the large antenna pad has been strained possibly severing the internal connection. Does anyone know where this pad traces to and if it is possible to solder a small wire to repair this. Thanks in advance... Twisterfan |
08-16-2010, 13:24 | #5 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1370687 Status: Offline Thanks Meter: 0 | What did you discover Chris? Hi Chris, I seem to have the same issue as you. Did you manage to trace the wire to the aerial? Are you able to take a photo of your fix? Any help is appreciated Cheers Aussie280 |
08-16-2010, 13:48 | #6 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 717129 Status: Offline Thanks Meter: 11 | above the antenna on the PCB there's a small oblong sticker. Under this sticker you can scratch the surface to reveal the contact on the board. Solder a wire from here to the antenna contact at the bottom of the board |
pls Administrator add section iphone Hardware Repair Area | quickgsm | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 05-04-2009 07:24 |
-= Disassembly of iPhone and repair guide =- | bronce | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 12-08-2008 08:03 |
iphone imei repair | mojodojo | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 03-15-2008 15:25 |
PCB Repair Advice ( York UK ) | MarkyB1001 | Hardware Repair by brands | 2 | 01-08-2007 00:16 |
W900i PCB repair | mitsub | Sony Ericsson Hardware Repair | 0 | 11-19-2006 07:27 |
