10-05-2018, 09:10 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | iphone4 7.1.2 hactivate tool poblem tring to bypass iphone4 7.1.2 with iPhone 4 hectivate tool all ios facing 2 problem 1= when press "Run SSH_RD Tool java page open set connect in dfu mode all process done but set power on ...it should remain on apple logo with a bar 2= some time in java page process hang and set in recovery mode then with ireb have to exit recovery mode also flash it but still unable to bypass any idea to fix it |
10-30-2018, 22:10 | #5 (permalink) |
Freak Poster Join Date: Aug 2011 Location: phillippines
Member: 1634236 Status: Offline Sonork: whatsapp:+639299673791 Thanks Meter: 11 | install older version of itunes and used 32bit system thats it everything will be ok..its also happened to me and thats solved my problem |
11-05-2018, 07:01 | #6 (permalink) | |
Junior Member Join Date: May 2017 Location: france
Member: 2715120 Status: Offline Thanks Meter: 2 | Quote:
yes i used older version of itunes as it said on the ssh.jar file the configuration was perfect, but what you mean by 32bit system is it work only with windows 32bit ? because me i used windows 10 64bit!! it stuck like this and the phone reboot after | |
11-19-2018, 11:57 | #7 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | Quote:
have anyone solve it? | |
11-29-2018, 03:56 | #9 (permalink) |
Freak Poster Join Date: Sep 2006 Location: philippines
Member: 346345 Status: Offline Sonork: jhon18 Thanks Meter: 56 | if your pc installed latest update of itunes no longer to response hacktivate tool. for bypass iphone 4.. try to unstall latest itunes and install old version itunes to work perfectly hacktivate tool.. |
11-29-2018, 04:08 | #10 (permalink) |
Member: 1634236 Status: Offline Sonork: whatsapp:+639299673791 Thanks Meter: 11 | and try to install a 32bit system ur problem will be solved ..if the above mentioned tried den use 32bit sytem not a 64bit system coz its an old program |
